Thread: 85 350x carb elevation adjustments
    Guest
    I just bought a 350x from ohio, and I'm in NJ. The elevation there is about 850ft and here its 85 ft. I think I need to adjust the air screw, but I dont see one. It ran perfect in ohio, but here it's hard to start, backfires, wont idle or stay running. Let me know what you think, or how to adjust the air. Thanks
    Apr 2002
    s.w. michigan
    6,498
    carb
    my x manual says the stock jet (#138) is good 6000 feet and below.
    so that ain't it.
    pilot screw setting is doughtful in my opinion, running good in ohio, should run good in jersy.
    you sure you don't have it warmed up good or getting used to the starting /choke proceedure ?
    john
    Guest
    carb
    I started it once in ohio, when it was cold. One of my buddys tried to start it yesterday, and couldn't get it to run right, he might have had the choke wrong, but I doubt it. I havn't tried yet. I've been waiting till I get my new clutch plates in and the caliper rebuilt, but I want to find out what the problem could be. I'll play around with it this weekend. Any suggestions?
    Thanks
    Aug 2002
    332
    I would suggest that YOU go try to start it. If you got it to run in OH, then you should be the one to do it in NJ. Not eeryone uses the same procedure when starting/choking. I agree with John, the elevation should not make a difference. That is only about 0.55 psia difference in air pressure, not enough to make a difference.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
