Results 1 to 13 of 13
Thread: What type of paint to use on frame and swingarm
    markdb420's Avatar
    markdb420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Virginia Beach, VA
    413
    I am getting my frame and swingarm sandblasted primed and painted. I am having a local auto painter sandblast, prime and paint my frame and swingarm. He is going to use a sprayer and told me to get a quart of enamel for the frame and a pint of enamel for the swingarm. I know what colors I want, what type of paint do I need to buy for him to use? Thanks.
    06 Yamaha Bruin 4x4
    04 TRX Rancher 400 AT 4x4 GScape
    86 ATC 250es Big Red
    84 ATC 200s (31 yrs running strong)
    13 F150 4x4 SuperCrew 5.0
    00 Excursion V-10 lifted with 35s
    ____________________________
    Gone
    07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
    Jul 2004
    north carolina
    101
    i would suggest powdercoating if you can find someone that does it. it is a whole lot more durable and holds up great
    05 trx 450r
    2004 kawasaki mojave
    use to own 84 and 85 honda 250r
    crankem up hit the juice and throw some roost
    Mar 2003
    Barnesville,Ohio
    2,298
    yes...do a powdercoat if you can. but for paint i would use PJ1 frame paint if i had to paint it
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    If you have a auto paint store in town go and ask them about what kind of paint to use.
    85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
    85 Big Red
    83 KLT200
    82 ATC200
    If it aint broke fix it anyway because it soon will be
    markdb420's Avatar
    May 2003
    Virginia Beach, VA
    413
    Do they make PJ1 that doesn't come in a spray bomb can?
    06 Yamaha Bruin 4x4
    Gone
    Apr 2003
    Spanaway, WA
    1,242
    i'd find a good industrial paint
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Ithaca, NY
    2,596
    I have found that powder coat does not seal out moisture very well. everything I have ever seen P-coated rusted faster than it should have, like snowplows, a certain swingarm I have, I dont see what all the hub bub is aobut. It may take a whack, but still not that impressed with its sealing ability, maybe its just the multiple products I saw done by the same inept powdercoater????? what gives?
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Michigan
    1,220
    If you have to paint, dupont centari (single stage) mixed with a 2000 gloss pack is a very hard paint if its oven cured. I have also heard good things about POR 15. http://www.por15.com/ Powder coating is stronger and may even be cheaper than painting. Some paint colors are very expensive, then you have to have primers, reducers, hardeners, which all add up. I would strongly sugest you price out your materials before you decide to paint, then price powdercoating and weigh the differences. Basically, you get what you pay for when it comes to a paint job.
    Michigan
    1,220
    Quote Originally Posted by Trikeaholic
    That is very true, look at all the plows out there and the powder only lasts a couple years. It comes off in huge sheets, and nobody mentions what it costs to blast a part that has been powdercaoted. The guy that does my frames charges double for a frame if its been powdercoated, why? because it takes twice the material to get it off compared to paint. I have asked my powdercoater about this and his explanation is the thickness. A good powdercoat job should be about 8 mils. max. The thicker it is, the easyer it will chip and flake off. If you notice on the plows, they put that stuff on alot thicker than 8 mils. The guy I use stands behind his stuff and says he will redo any parts that chip or flake off.
    My swingarm was $40 for powdercoat, I know I couldn't paint it for $40, not with the cost of primer, reducer, paint, hardener, sandpaper and then my time and then I don't have access to an oven any more to cure it properly. I can't even walk out of the paint store without dropping $100 on materials so powdercoating is definatly cheaper for me.
    markdb420's Avatar
    May 2003
    Virginia Beach, VA
    413
    I just have to buy the paint, the guy has all the thinner, reducers and hardeners that he'll need. Not too manychoices around here, after I made some calls.
    06 Yamaha Bruin 4x4
    Gone
    Michigan
    1,220
    What kind of paint does he normally spray? Not all reducers work in all brands so you may want to ask him what brand he normally uses.
    May 2002
    Southeastern Wisconsin
    3,658
    Sounds like you need to tell him to get it for you because like x.system said you can't just mix differetn paints with different reducers. I've powder coated all my restore jobs and from my results I'd never paint again. It's just like paint though, you need good prep to last a long time. As far as snow plows go I haven't seen anything make the long haul on them.
    Jul 2004
    north carolina
    101
    Quote Originally Posted by OldSchoolin86
    that was exactly my thought i do not think a snowplow is a good example of durability lets put enamel on that plow and see how long it holds up
    05 trx 450r
