Results 1 to 15 of 51
Thread: bad day for my 200x!
    Oswego, IL
    1,858
    ok we went riding on my pond and then on the trails then we were going to go to a friends house taht lived about 15min away. well as soon as we got on the road i was in about 4th gear and giving it alot of gas then all of a sudden it died. so i pulled in clutch and then let off so it started again. )like being pull started i guess) and then i went to give it gas it died and a big puff of whitish blue smoke came out. and i cant get it started. and there isnt alot of compression. did i blow a ring? or is it somthing with my valves. the motor doesnt even have 2hrs. on it scince rebuild. its a 12.1 piston and im not getting alot of comresssion. im going to pull the motor tomarrow after i fix my sled. and tear it apart this weekend. i hope it is just a ring on the piston. i replaced alot of stuff but cam, valves. and valve springs. i also didnt adjust my valves because it runs fine. well, did. some one help me out here.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    are you running high octane fuel?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Jun 2004
    Brazil, Indiana
    1,389
    sounded like a ring to me
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Rittman, Ohio
    6,276
    Quote Originally Posted by 83185s
    Could you please explain how you were able to arrive at that conclusion from the information given? Im always interested in learning something new.
    Oswego, IL
    1,858
    well bad compression has to be the valves or the rings right tim? and im not running high octane gas.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Jun 2004
    Brazil, Indiana
    1,389
    i came to the conclusion because u lost a lot of compression and u said it suddenly blew out a bunch of whitish blue smoke came out..blue = oil and white also = oil or to much air.. which means u blew a ring and the air was being sucked into the head from the bottom end...i think...im not the smartest one here but that sounds more logical than anything else if u hadnt broke in the motor yet
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    Rittman, Ohio
    6,276
    Quote Originally Posted by vartiak15
    Yes, or a seizure or hole in the piston, but there is no way anybody can tell you without opening it up and inspecting it. Ive never heard of a ring "blowing". When they break is normally from another problem, and they usually do lots of damage, but more often they get stuck compressed in the piston grooves from a meltdown or seizure.
    Rittman, Ohio
    6,276
    What is it that makes you believe it that its not a valve?
    Oswego, IL
    1,858
    what would be wrong with the valve? sticking or what? ill take it apart this weekend.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Jul 2004
    Mud hill. close to water !
    3,658
    With any luck nothing got in the tranny..... for your sake i hope so !!!
    Currently :
    Dec 2002
    salem, nh
    1,339
    12:1 piston and not your not running high octane?????????? did u really build that and then run 87 gas thru that thing??????????????
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Oswego, IL
    1,858
    lol. thats what i say but my dad says it will run fine just not at its top potential(sp). so it will work and run but not as fast as possible. ive got some octane boost. mabye ill throw a lil of that in it i ever get it running. that didnt cause the problem tho. well i dont see how it could.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Phoenix, AZ.
    6,719
    Jun 2004
    Brazil, Indiana
    1,389
    i dunno tim sr. i just kinda did..im not the smartest one alive and i dont always know what im talking about but thats just what i believe it is..(not trying to be a smart ass)
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    Jul 2004
    3,658
    have you removed your spark plug to inspect how it was running ? rich lean .....
    Currently :
