Results 1 to 9 of 9
Thread: Banshee rear end in a Z?
    Mar 2004
    North Central Ohio!!
    2,712
    How much of the banshee rear will fit in the Z?
    Can I use the whole carrier if I switch to the Banshee rear brake?
    Do I even need to use the Banshee rear brake with the Banshee carrier?
    I'm eye balling that x-33 set-up on ebay. Just wondering if it will work or not!
    Front royal, va
    2,186
    i think it will work, i own both, but you will need EVERYTHING from carrier, sproket hub, disc hub, and of course the caliper
    Mar 2004
    2,712
    Since your checking them both out, I was thinking of buying the rear lowering kit for the Banshee to use in the Z. Does it look like that will work?
    I have a longer shock on the back and it sits about 2" higher. I'd like to lower it back down.
    Watertown, New York 13601
    3,382
    Quote Originally Posted by Derrick Adams
    It will work.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Front royal, va
    2,186
    the spacing in the middle is the same, as is the four bolt holes, they all line up, but you will need the complete setup to work
    Rittman, Ohio
    6,276
    Ive never tried it, but the early Banshee carriers have 4 bolts like the TriZ, and the later years use two long bolts. Which one are you trying to adapt?
    Mar 2004
    2,712
    Kind of eye balling this one. I know it's alot of money, but it surely should never fail! Kind of watching to see how high it goes.
    Mar 2004
    2,712
    I see what you mean about the 2 bolts. Wonder if it works?
    Awful expensive experiment!
    cedar falls, IA
    546
    can anyone give me a measurement on a banshee carrier? I would like to know how far apart the mounting tabs are (the tabs that the long bolts go thru that mount the carrier to the swing arm) , outside to outside please. curious to seehow close they are to the tecate. if it will fit inside the tecate swingarm this will open alot of options to tecate guys that cant find those rare aftermarket axles and allow for the option of running different size rims.
    Joe
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
