Results 1 to 8 of 8
Thread: 85 200S Recoil problem- HELP!!
    Jan 2005
    tracy CA
    4
    Unhappy 85 200S Recoil problem- HELP!!
    Howdy folks,
    HELP!!
    We have a problem with our 1985 200S recoil starter assembly, that is, we have taken it apart and have successfully replaced the starter rope, no problems, BUT, now we cannot figure out how to get the plastic ring (which connects to and activates the cylinder decompression cable) properly attached to the 4-turn tension spring that fits (somehow) inside of this ring. We have the Clymer manual, which is about as clear as a glass of mud when it comes to assembling this spring to the plastic ring. Any help would be much appreciated, as we spent over two hours fiddling with this thing to the point of a migraine, and can't figure out how the heck it is supposed to go together.
    We were as observant as possible when taking it apart, but unfortunately, you can't see anything when it's assembled and when it comes apart, there is no way to see how it was actually all fitting together.
    Jan 2005
    tracy CA
    4
    Come on guys! Someone has to know how this thing goes together!!
    Jan 2005
    uk manchester
    22
    hi,i have done this myself twice,just today i have striped it down and rebuilt it but to put it into words is gonna be hard
    after you have put the the washer and circlip on(not sure what you guys call a circlip)you are left with the large plastic ring and spring and also a curved steel slide with slot in it you attach the cable to this then you put the spring around the center of the recoil on the plastic ring there is a slot for the steel slide put this in first before pushing onto the recoil be sure that the springend
    comes through the plastic ring and also through steel slide
    i know it not very clear but as i said its hard to put into words
    Columbus Nebraska
    138
    lol Unless you got a high comp piston in you dont really need it. I just tore mine off and mine has pretty good compression, i can start it fine and im not too tough.
    1985 ATC 200S--no spark, parts for sale
    85 YTM 125--needs a carb cleaning and set up
    79 Suzuki TC125--dirtbike, now fully restored!
    84 ATC 200x--Need a good frame, rear caliper bracket, and a blown up or barley running motor with a good clutch.
    Message me if your interested or have anything i need
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    LMAO
    I did the same thing untill I threw it acrossed the yard put the starter back together and went riding, and soon after that noticed the previous owner had melted the cable on the block anyway.
    Stock you shouldnt need it. Whens the last time you heard an ATC decompression assembly actually working anyway??:P
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    If you decide to remove the cable, be sure to cover the hole in the starter to stop dirt/sand etc getting in there. Its a sure way to kill the starter not to mention the electrics.
    Jan 2005
    tracy CA
    4
    Thanks MidnightExpress and all you guys.... I did try it without the decompression cable hooked up, but, I guess mine has good compression (it does have pretty low hours) because it is much harder to start without the decomp hooked up. My dad often rides it (he's 79) and I'd like it to be the way it was before....So I will try re-assembling it with Midnight's guidance this week and will report back. -Rob
    Jan 2005
    tracy CA
    4
    Thanks to MidnightExpress for the help. I was able to get the decomp mechanism re-assembled and everything is working as it should. -Rob
