Thread: Tech question for the Guru's on site,please help
    Jan 2005
    Columbia,Pa
    3
    I have recentley purchased a 1985 200s trike,I am having problems with it going in gear,The gears feel fine when I manually go threw w the shifter(not runnin),but it will not enguage to turn the piston over.I have no grinding or anything,when pushing it,Its acts as if its in neutral.The motor has good compression and seems to turnover fine
    Another question I have is,Is there supposed to be 2 shifters on this?It seems like the shaft sticking out above my shifter should have something on it?
    Any help would greatly be appreciated,we just got 10 inches of snow and I can't go tear it up.Thanks in advance and once again anyhelp would be very much appreciated,feel free to email or post any suggestions you may have.
    thanks again
    Byron
    Sooperglyde73@aol.com
    Great site also
    Nov 2002
    Kirkville, NY
    3,831
    Welcome to 3 Wheeler World!
    Ok, for starters the second shifter shaft you see is really for a neutral indicator. It is a little plastic arrow that sticks one there to show what you are in neutral. You can get a new one from your Honda dealer for about $2; lots of trikes are missing them.
    For starters on the shifting problem you should try adjusting the clutch. To do that, loosen up the 12mm lock nut that is on the right side engine cover. Then turn the screw that is inside the nut counterclockwise until you feel a little resistance then turn it clockwise 1/4 of a turn. Now tighten up the locknut but make sure the screw does not turn.
    If the adjustment doesn't help let us know and we can do on from there.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Columbus Nebraska
    138
    First we'll go with the easy one. That other shaft is nost likely where your neutral indicator goes. And as for the no gears part, mine did the same thing. On the right side of the motor there is a nut and sticking out of the case, you loosen the nut, and with a flat head screw drive your righten that shaft untill you feel resistance, once you feel resistance turn it the opposite way one quarter turn, hold the screwdriver there (to keep the shaft from turning) and with an open end wrench (try doin it with a socket your not gonna get the job done, lol ) and tighten the nut. Just sounds like your transmission is loosened up, doin this fixed mine and it works great, i believe this process is in your manual.
    1985 ATC 200S--no spark, parts for sale
    85 YTM 125--needs a carb cleaning and set up
    79 Suzuki TC125--dirtbike, now fully restored!
    84 ATC 200x--Need a good frame, rear caliper bracket, and a blown up or barley running motor with a good clutch.
    Message me if your interested or have anything i need
    Oswego NY
    1,935
    Welcome to the site. and good luck w/ the 200s
    The second shaft is prob the gear indecator, it should have a white circle thing w/ a little pointer, if I remember my 200s. The gear problem could be alot of things, First I would check the chain / sprocket. Make sure everything it in good working order. 2nd check the shifter splines and make sure it is really changing a gear. From there you need to get into the motor and clutch adjustment, check the easy stuff and get back to us, I am sure you will get the help you are looking for.
    GOOD LUCK
    MIK6 / Mike
    New England Ride 4/13
    Jan 2005
    Columbia,Pa
    3
    thankyou,It's great to see that so manny people still have intrest in the 3 -wheeler'
    thanks alot,I will try that tommorow,first thing.Thanks for the rapid responses from evryone,your input in very much appreciated.This site is wild.I just told a few of my freinds about this site and they are loggin onto it now.thanks in advance again guys
    Byron
