Results 1 to 14 of 14
Thread: '84 Tecate troubleshooting questions
    Nov 2004
    Salisbury, NC
    42
    Hey guys, (I apologize in advance for the long post)
    I'm about halfway through the restoration of my '84 Tecate. I bought it about 4 or 5 years ago and just got around to working on it....I knew it had ignition problems when I bought it but I knew it could be fixed.
    When I bought the trike, the guy I bought it from said he dropped the flywheel and knocked the magnets out....he glued them back in....when I checked the magnets (there are four, two positive and two negative) he had them arranged ++ --, I took them out and reposition them as +-+-.
    The problem is I'm not exactly sure what the problem is. When I got home from work today I popped the stator/flywheel in and plugged all the wires together.
    I have one of those little ignition testers, basically just a small light bulb inline on the plug wire. When I turn the engine over I get a very weak spark, but at least theres a spark.
    OK heres the questions...
    1. Did I mess up the flywheel by going +-+- ?
    2. Could the stator cause a weak spark, or do they simply work or not work?
    3. Maybe a coil, CDI, or something I'm missing....
    I had intended to just replace the flywheel stator, but I hate to make a $200 mistake, any help will be greatly appreciated.
    Attached Thumbnails Attached Thumbnails Motoboys Tecate.JPG   Ignition tester.JPG
    Jun 2003
    englishtown NJ
    2,676
    replace both the stator anf flywheel for peace of mind. the magnets tend to come loose and take out the stator.
    Newfoundland
    5,280
    Buy a new Ricky stator and flywheel like deathman said the stockers are a poor design. You have a very nice project going there, a profile pic from the other side would be nice to see if you have one. Best of luck with finishing it.
    Apollo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Fort Worth, Texas
    190
    Nice, clean restore. Great job.
    Nov 2004
    Lemoore, Ca
    44
    did anyone notice the spark plug wire near the coil? looks to be worn out right there from the tank, could that also be part of the problem?
    If its on, Lets get it over with!
    1985 KXT250 Tecate, Well sort of...84 frame, 85 engine, 86 front end
    Nov 2004
    Salisbury, NC
    42
    tecate250RR, you're right, the coil wire is worn near the coil, but its not through the insulation. I had the coil checked at a garage and they said it was fine. They put it some fancy tester they had.
    I plan on replacing it anyway because this one is not original, it must be from a junk yard because it has "KX 125" scratched into the paint.
    May 2003
    Houston, Texas
    2,409
    One good looking project.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Apr 2003
    Central New York
    1,864
    Tecate Project
    Yes go to Ricky Stator and get new for piece of mind. A sweet project like that deserves the best, not questionable parts. Im allmost done with my Tecate and from experience its better to know there isnt going to be any failures. Lets see some more Pics and put it in the Restoration section on this site.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Nov 2004
    Salisbury, NC
    42
    Quote Originally Posted by MEATbox[mHz]
    Your right MEATbox, I'll be ordering a flywheel/stator from Ricky Stator in the future.
    I saw your project on there, it looks great, do you have any more recent photos?
    My project is on a much smaller budget, "repair what I can and grab the s" is the motto for this one.
    I'm also interested in putting my project in the restoration section.
    I went and checked it out, it says to "contact me if you're interested....." but it doesn't say who to contact.
    Or maybe I overlooked something?
    Nov 2004
    Lemoore, Ca
    44
    cool, just something i noticed. nice job on the trike.
    Apr 2003
    Central New York
    1,864
    Contact for Restoration page
    http://www.3wheelerworld.com/team.shtml
    thats the Page. Its the home page the look for the 3ww team. They are cool and will hook you up when they have the time. Do a good write up about your project so far and take some good pics, they will do the rest. With yours there will be 3 Tecates on the restoration page.
    84-85 Custom Tecate
    Nov 2004
    Salisbury, NC
    42
    Thanks for the info MEATbox, I'll try to get the info together this weekend, it depends on the weather.
    Its supposed to be cold and raining/snowing this weekend and my computer usage increases as the weather gets worse, I rarely touch my home computer in the summer time.
    250SX's Avatar
    250SX is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Raymond, MS CSA
    310
    I can get the stator/flywheel combos for less than $200. Email me when you get ready to buy one.
    '8? ATC70s
    '8? ALT50
    '8? YT175
    '83 ATC185S
    (3) '85 ATC250ES
    (5) '85 YTZ250
    (2) '85 ATC250R
    (5.5) '86 KXT250
    '86 YTZ250
    '86 KXT500
    '86 ATC350X
    '87 KXT250
    '87 ATC250SX
    and a couple of Mancos
    Nov 2004
    Salisbury, NC
    42
    Quote Originally Posted by 250SX
    Email sent................
