Results 1 to 15 of 24
Thread: Good trade?
    Jan 2005
    CA
    57
    Good trade?
    I have a 85 350x, Some Broken Plastics, Runs superstrong, lights are there, no bulbs, No tailight. Stock minus Some new handle bars, i think they are FLY bars or something, aftermarket Tank fins, and A UNI filter, which I dont think is stock, (Im new to this) Frame was cracked but has been welded, and is very strong. Dent in the tank.
    in a flat trade for a 1985 lt250
    with new plastics, new ceet cover, new fmf exhaust, new clutch, only thing is it needs a new top end, was last running 1 week ago. Because it has been bored over to many times.So it hasnt been sitting around for ever. the whole thing.
    So my question is, do you think thats a good trade? He is only asking 750$ for the bike, but I dont have that kinda dough, I know I could sell my bike for atleast a bit more then that. but by that time I think the bike will have been sold. he has said he would trade but not pay anything out on it.
    I really want a quad and so does the wife, she wont touch the 3 wheeler (Crashed a couple times) and I am trying to get her more involved in the sport.
    So you guys tell me, do you think its good,
    also any clue as to how much it would cost to fix this thing? thanks - Morgan
    Houston,Texas
    1,044
    I would do it. It should cost less than $160 to fix that top end. That is, if you do it yourself.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Sounds about right, could probably be a little cheaper. I know the 85's are notorious for broken frames, and there was something else major too, but I cant remember. The cost will be about $200 if you need a new cylinder sleeve, and about $110 for a top end kit (piston,piston pin,rings,connecting rod bearing, and gaskets).
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Jan 2005
    CA
    57
    whrere could I find one of these sleeves at? Thats what he said it would need? What would be the level of difficulty involved in doing the work my self? I have a good amount of standard tools. I was a mechaninc in the army, but never did internal engine stuff so I am handy with a wrench just never tore apart an engine.
    I think the swingarms liked to crack also on them
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Jan 2005
    CA
    57
    my uncle has one, same year and he just got a new swing arm, If mine did go i guess i would buy a aftermarket one, which would probably be more durable,
    I found a sleeve on Denniskirk, Not bad price, my question is, is how would you change that thing, looks awfully easy to mess up, I am sure you would have to apply heat to the jug to loosed up the old sleeve, then press it out, and then press the new one in and try to match everything up, looks preety tuff. Or am I way off?
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    www.denniskirk.com go to your local dealer or a parts unlimited dealer. You will not be able to put the sleeve in by yourself, a shop would have to do that, unless you have the tools and experience. I believe the sleeves have to be pressed out and back in.
    Currently Trikeless!!!
    Installing sleeves should only be done by experienced shops. I think you can send it to weisco and they could set you up.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Central PA
    1,952
    Yeah cylinders need to be professionally done costs about $100 maybe more. You could check e-bay for a complete jug, but I wouldnt buy anything that is bored 30 over, if you do this, it's going to be about $40 to get a cylinder bored to fit your piston, if you do this, make sure you dont just get your cylinder bored at 40 over even though you ordered a 40 over piston, the piston must be measured to ensure the size of boring you'll need.
    PastRides
    SOON MY PRECIOUS!
    Jan 2005
    CA
    57
    this one would be bored over to much correct? or does this look ok,
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
    Just got a quote for a sleeve job, and they would take atleast, 2.5 weeks and i would either have drive it down and pick it up, 1 hour each way (With absoulty no traffic, which is impossible to find here in ca so roughly 2 hrs each way) or pay shipping cost. For 245.61$ seems a little steep.
    Dec 2003
    SE PA
    683
    LT250R's were notoriously unreliable. My buddy had a few of them, I remember we were rebuilding them more than we were riding them. The needle bearings in the suspension (ront a-arms and rear linkage) all go bad, there are no grease points and they have to be taken apart every year and greased. $600+ for all the parts if these bearings are shot. Pre '87 LT250R was a total piece of crap. Sounds cheap enough though.
    Jan 2005
    CA
    57
    are the parts upgradeable? the front arms? Also, I just found out it has new rear tires and rims also.
    Central PA
    1,952
    I think the ebay ad may be wrong, 85-86 had 247'cc, and all other years had 246.8 cc's, not 249 cc's. Also my dennis kirk catalog shows that 72mm is the highest bore piston they sell for the quadracer, so I think you should shy away from that deal.
    PastRides
    SOON MY PRECIOUS!
    Newfoundland
    5,280
    Keep the 350X if it runs and has no major probs. The fourstroke power delivery of the X versus the LT250R is much more mellow and easy to control which would be easier on the wife lol. Theres nothing wrong with a trikes handling, its just the person thats riding it(dont mean to step on your toes). Teach your wife how to ride it and you should have no complaints OR at least wait for a better trade.
    markdb420's Avatar
    markdb420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Virginia Beach, VA
    413
    That cylinder head looks to be a 4 stroke model, which it will not fit on the LT 250R models. The $246 wood be ok if they are providing the sleeve and new piston and rings. Otherwise I'd run from this quad, as it will be unreliable and costly to find parts for as the 87 and up were far more desired and had better parts availability.
    06 Yamaha Bruin 4x4
    04 TRX Rancher 400 AT 4x4 GScape
    86 ATC 250es Big Red
    84 ATC 200s (31 yrs running strong)
    13 F150 4x4 SuperCrew 5.0
    00 Excursion V-10 lifted with 35s
    ____________________________
    Gone
    07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
