Results 1 to 8 of 8
Thread: Tri-z fuel tank
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    Tri-z fuel tank
    is there supposed to be a nipple on the bottom of the tank? like directly on the bottom not on the side? on my tank looks like someone patched the tank with some platic filler or something. total i have 3 nipples, is there supposed to be 4 or is mine right?
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    What do you mean by nipple? A fuel line fitting?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Watertown, New York 13601
    3,382
    I have never noticed a nipples on my tank.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Central PA
    1,952
    Hey twgranger, what size wheels and Razr's do you have on your Z? Looks sweet.
    PastRides
    SOON MY PRECIOUS!
    3,382
    The rear are 20x11x10 and the front is 23x8x12. The tires were huge when i bought it, they had to go!!
    2006 YFZ 450
    May 2003
    556
    yes, a fuel line fitting, couldnt think of what to call them. i refer to them as nipples, dont ask i guess.
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    Central PA
    1,952
    Yeah, there should be 4. One at the top back of the tank, (breather), one by the fill cap (either a return, or something to do with vaccum), one on the side of the tank, (your top left fitting on the pump gets hooked to this one, it's your regular fuel supply), and the one it sounds like you are missing is towards the bottom, it gets hooked up to the bottom left fitting on your pump(this is your reserve supply).
    PastRides
    SOON MY PRECIOUS!
    May 2003
    556
    thats what i thought. damnit, now i have another thing to buy. thanks
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
