Results 1 to 9 of 9
Thread: how do i test coil on 200x?
    Jan 2005
    florida
    41
    i dont think im getting any spark from my 85 200x
    i took the plug out and left it hooked up to the plug wire
    and grounded it to the motor and kicked it over but i didnt see any
    spark? i also held my finger to the end of the plug and kicked it over and it didnt shock me.
    does this mean the coil is bad?
    and is there a better way to test for spark
    im also thinking it could be the kill switch but i doubt it...
    any help would be appreciated.
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    The coil isnt commonly a problem. I would be just holding the spark plug lead 1/2" from the engine and see if you get a spark (or hold the wire). That eliminates the problem being the spark plug.
    You can disconnect your kill switch by unplugging the wire that goes from the CDI box (the one with heaps of wires coming from it) to the kill switch. All the kill switch does is sends this wire to ground so make sure that it doesnt touch anything when its unplugged or you will have no spark.
    Check that you have all your wires going to the right places and that they are all plugged in correctly.
    Check the pickup (located in the head) isnt touching the rotor or that its not too far away. If it has been touching make sure that it isnt damage. Adjust as necessary.
    Make sure that the coil is grounded well. Sometimes corosion can build up and affect spark. Also try a different spark plug lead or check that its hooked to the coil properly.
    Only thing left to check is that there is charge comming from the electrics located in the bottom of the motor. Attach a small light bulb to the wire and ground the bulb. Give it a kick or two and see if you have light. Sometimes the charging coils can get damaged if the flywheel picks up some metal (its magnetic remember) and spins around so the metal hits the charge coils and damages them. Off to the wreckers or salvage yard or whatever you want to call it if this is the case.
    Good luck.
    Jan 2005
    florida
    41
    on the plug wire going into the coil
    the wire is only sticking out like 1/32 of an inch
    and isnt connected to anything, is this right?
    also, there is no headlight, that wouldnt have my wiring thrown off would it?
    and when you say the electrics in the bottom of the motor are you talking about the two wires coming out of the stator assembly?
    if so which one do i hook the light to? (to test the charging coils)
    i did not know that the charging coils could get damaged
    so i will be scared when i try this..
    and you say there is no way to repair that if that is the case??
    Thanks a lot for your advice.
    Jan 2005
    330
    That plug lead sounds fine.
    I am talking about the two wires coming from the stator assembly. The headlight hooks to the yellow wire and the black is for the ignition system. Hook a small bulb to the black wire to see if it is producing any electricity (or use a amp meter if you have one).
    Dont be scared to do it because if it doesnt work further inspection may find a damage wire thats earthing out or infact the wire is completely snapped off! You can take off the flywheel and inspect the charging system for damage but if its producing power then probably no need.
    Dec 2002
    salem, nh
    1,339
    u have a bad stator, i had the same thing happen a couple months ago on my 200x
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Jan 2005
    florida
    41
    well, i hooked up a wire to the ignition wire coming from the stator
    and grounded it, kicked it over a couple of times hooked to a light
    nothing happened, so i stuck it to my tongue a couple of times and
    it didnt shock me.
    i took the stator off it looks ok, but someone may have switched the coils
    from another bike (not a 200x) out on it.
    the screws that hold them in are almost stripped.
    is the only charging system inside the stator or is there something else behind the flywheel and can i take the flywheel off without tearing anything up? in other words it will go right back on?
    but as far as i know right now i think its the stator.
    will probably try a new one before i do anything else.
    Washingtons Crossing, Pa.
    2,977
    ...... so i stuck it to my tongue a couple of times and
    it didnt shock me.
    Brilliant!.
    Jan 2005
    330
    You sure you arent an aussie? How did you manage to kick it AND hold your tongue on the wire? I agree BRILLIANT!
    What happens when you do that to the headlight wire (the yellow one)
    Jan 2005
    florida
    41
    beleive it or not i actually wanted it to shock me!
    i didnt try it with the yellow wire.
    just got this motor and have yet to fire it..
    its just like the 84 i had, it nickeled and dimed me to death
    befroe its maiden voyage.
    i stripped it down to the frame and partially restored it!
    i bought it for 100$ and put about 800$ in it
    i had it running like a champ.
    it seems to me when you really weigh it up you can get just about
    any old 3 wheeler running for around a grand.
    which is really not that much money to keep the dream alive.
    looks like ive started over again with an 85.
    this time i might just restore it to mint and TRY to hold on to it.
    i also have a big red that came with this one and its getting spark!!!
