Results 1 to 15 of 27
Thread: Will a Bigger motor fit in an SX?
    springville, PA
    6,185
    I have some time on my hands this winter and was thinking that since i have so many SXs I would trick one out. My first plan is to put a bigger motor in it if possible. I was thinking like a rancher, forman or even a diff make like a 350 big bear. Has this been tried by anyone?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jul 2004
    Mud hill. close to water !
    3,658
    If you're gonna do up an SX.. make sure to work in Reverse and elec start !
    Need to stay with the theme !
    just more power !!
    argh arghharrrgh.
    Currently :
    springville, PA
    6,185
    Hell Yeah! Tool man! Gonna Make my baby purrrrrr.
    Nate
    R.I.P HRR
    Quote Originally Posted by 250sxwheeliepop
    If you want to trick one out, figure out a rear suspension improvement. The last thing the stock SX needs is a bigger, faster, heavier motor to try and ride without being tossed off. That rear pogo stick should be priority number one. I have been promising alot of guys that I would come up with something for the SX and I am still working on it. I'm not just gonna hack anything on there, I want it to look and work great.
    springville, PA
    6,185
    Well if the motor required a diff rear then I could try to make mounts so the shocks would work. The mounts im speaking of go at the top of the shock.
    Nate
    R.I.P HRR
    Front royal, va
    2,186
    ever try the 86 trx 3504x4??, or a dirrect bolt in, an 88-99 trx 300 4x4?? same cases, different stroke
    springville, PA
    6,185
    Im making a list from what has been said in here and what I think. Any Adiitions? and remember I'd like to know what higher cc motor i can put in
    So far.....
    Things that need to be done to trick out my SX:
    Different (refered to as diff) rear suspension
    Smaller tires in back
    New plastics all around (200x up front and 350x rear)
    New motor
    350x headlights
    Twist throttle
    New exhaust (probably cobra megaphone)
    Bigger carburetor
    K&N or UNI air filter
    Any other suggestions?
    Nate
    R.I.P HRR
    springville, PA
    6,185
    Quote Originally Posted by 03 ORANGE SHEE
    So far I havent tried anything yet. Also what makes the wheels up front turn in 4x4, isnt there another drive shaft that comes out of the motor for the front?
    Nate
    R.I.P HRR
    Jun 2004
    potsdam ny
    1,227
    [QUOTE=250sxwheeliepop]
    QUOTE]
    He means differential rear suspension, not different...
    springville, PA
    6,185
    I dont think I mean differential. If I have time im gonna try to make a different rear suspention
    ADDITION: diff is the way I write different in short hand
    Nate
    R.I.P HRR
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    Might as well get a 400ex jug and sleeve it out to 440, that should bolt up to your lower end. Hopefully you can get the 2 headpipes around the downtube. Do that and then upgrade the suspension front and back. Then worry about the piddly stuff-(headlights, stickers, etc.)
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Yamahammer490's Avatar
    Yamahammer490 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    That picture looks like the quad has independent rear suspension. I've always wondered how a trike would work with IRS.
    My guess is that it would either be real tippy and handle like crap OR it would give you a little leaning ability and handle more like a bike. Sorry to get too far off the track but the picture sparked my interest.
    Aside from that, I like the SX with the wide front tire so please don't put a "X" front end on it.
    CURRENT RIDES:
    1988 Tri-Z 350 Twin
    1985 1/2 Tri-Z
    1984 IT490
    IMPORTANT: Those of you with an overwhelming fear of
    the unknown will be gratified to learn that there is no hidden message revealed by reading this backwards, so just ignore that Alert Notice from Microsoft.
    Washingtons Crossing, Pa.
    2,977
    Personally, for all the work it would require to get a TRX350 motor or even a TRX300 mill in there you really need to ask yourself if its worth it. I can guarantee the 250SX motor probably has more ponies stock than the 300 or maybe even the 350. Just because they have more cc's dosent mean they put out the kind of power a sport bike would need. Even though the SX motor is basically the 250ES utility motor, its tuned differently. My advice would be to work your motor - first thing I would do is look for an aftermarket exhaust, more aggressive cam and drop a medium compression or hi-comp Wiseco in it. You will see far better results.
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    There use to be a 300 kit, I think four stroke tech made it (fst racing).
    I'd put a 200x front end on, probably dont want to go too big on a carb, as you will loose bottom end the bigger you go, I hear cobra's are junk, might want to see if they made a supertrapp or DG system for it. Another upgrade is an 87 rear end. I hear they spice up the earlier models. Your going to want to watch how you mod the suspension, the shaft is to one side, and when you start playing around with independant units you'll have to measure pinion angles so you dont go binding your drivetrain.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    why not just leave the 250sx alone and buy like a 200x or 350x.sounds like you need one...
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
