Results 1 to 15 of 16
Thread: 1980 atc110
    Jan 2005
    Derbyshire ENGLAND
    39
    1980 atc110
    First of all, Hello to you all.
    i've just found your site and hope you can help, I've got a1980 atc110, i've bought it as a non runner, the problem being no spark at the plug, if i take the plug out and stick my finger in the cap and turn the engine over slowly it gives me a shock but once i connect it to a plug there is no spark. please help.
    Jul 2004
    Mud hill. close to water !
    3,658
    Have you tried a new plug ? and check the gap of the one you have.
    oh. and welcome aboard !!! l
    Currently :
    Jan 2005
    Derbyshire ENGLAND
    39
    Thanks.
    I've checked the plug, it works when i try it on one of my tri-z's.
    Jul 2004
    3,658
    I don't know for sure about the 110.. but on the 200's if you follow the wire comming from the plug it connects to the frame ( sorry, don't know the name of the part ) but the contacts with the frame need to be clean for a good strong spark.. might want to clean the contacts out some.
    Currently :
    Jan 2005
    Derbyshire ENGLAND
    39
    Ive cleaned up all the contacts, could it be something to do with the points, im not used to these?
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    I have a 1980 110.
    Check the points and clean the contacts. Mine were glazed. had spark, but was weak.
    Install a NGK plug too. The Denso and champion plugs don't last too long.
    Jan 2005
    Derbyshire ENGLAND
    39
    thanks, i'll try that tonight,
    are the parts on the 110 engine interchangable with ones from a 90 or a 70, parts like the points etc
    Jan 2005
    Derbyshire ENGLAND
    39
    i've just been out to look at the points and when i turn the engine over the points are not opening does anyone know the correct gap that they need to be, does this sound like it could be whats causing my problem?
    Aug 2002
    Creswell, OR
    889
    ..03 If I remember correctly. I will get my manual this afternoon and confirm that. Yes the spark and your opening lead me to believe you need to adjust and/or replace the points. Points are incredibly cheap if the adjustment doesnt work just replace them. Oh yeah adjust at F not T. Comman mistake.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Jan 2005
    Derbyshire ENGLAND
    39
    What do you mean by 'adjust at F not T'?
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by RASHER
    Clean the contacts with a little fine emory cloth or point file, gap them and put a dab of grease on the lobe.
    The coils seem rather durable. Check the primary wire coming off the coil going to the plug. I had to replace mine.
    Aug 2002
    Creswell, OR
    889
    On your flywheel, You have T and an F. T for timing, F for fire. When you line up the engine you use T, adjust valves, make sure timing chian is lined up and so on. You need your points to fire and or open right at F and should be fulley open right before T. Oh all this is done TDF which equals top dead center.
    www.3wheeler.org
    Jul 2004
    3,658
    PS: TDC on the compression stroke !!
    Currently :
    Jan 2005
    Derbyshire ENGLAND
    39
    thanks guys i'll get that checked tonight,
    Aug 2002
    Creswell, OR
    889
    Oh And I looked bad memory, sorry about that its between 0.3mm and .4mm
    www.3wheeler.org
