Thread: 86 R clutch (Hinson, 89 upgrade)
    Apollo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Fort Worth, Texas
    190
    Hey everybody, I need a new clutch for my 86 R. I want a new basket, but which one? I am getting new plates as well. Is the 89 upgrade kit available, worth it, and easy to install? Is there any other clutch parts available besides stock like an inner basket and hub, etc? What's everybody running? Thanks in advance.
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    i plan on doing the same upgrade for my 86r- i am very curious as well
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    I am using a Hinson cluch basket on my 1985 250r with the honda update clutch kit. I am running stock honda clutch discs also. Hinson instructions advise against using kevlar discs and recommends using stock discs. It has been working great for me. Good luck Glenn
    dogger is offline At The Back Of The Pack Arm chair racerFirst time rider
    yes the 89 upgrade kit is worth it. if you don't you stand a good change of loosing the little ball bearing on the clutch shaft and then you won't be able to disengage your clutch uless you like riding clutchless.....
