Results 1 to 15 of 16
Thread: Any truck mechanics out there?
    almac16 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Halifax, Nova Scotia, Canada
    226
    My truck started acting up on the way home from work today. Battery light came on and low charge on the indicator.
    Checked the battery it's getting 11.5 volts when off and 10.9 volts when idling.
    Manual says it should be around 12 when off and 14-15 when running.....so something isn't right.
    I didn't have anyone to rev it up but it seems if I have the RPMs up it shows that it is chargin fine and the battery light goes out.
    Any ideas? Could it be the voltage regulator? Or just a bad alternator.
    I priced the alternate at $250CDN at Canadian Tire (only place open at this time of day)
    Help!
    Aug 2004
    Ab Canada
    4,368
    alatanator more than likely, go to NAPA autoparts and take your old one, they will give a 80$ back for the core of the old one on the new one, and if it dosnt solve the problem you can take it back
    1985 Tri-Z-
    Jan 2004
    226
    Quote Originally Posted by My trike Sucks
    Are you sure you can take it back? most places won't let you return electrical parts
    Aug 2004
    Ab, canada
    1,222
    Its probably the alternator. Places take back starters and alternators so that they can rebuild the core and re-sell it. Napa should have the part. If the truck is a GMC/Chevy the alternators off of 12v electrical system fleetline series oliver tractors interchange with the truck alternators.
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
    Jan 2004
    226
    Maybe I should have said...... it's a 1998 F-150 4x4 with the 4.6L in it.
    Minnesota
    790
    Battery isn't being charged like is supposed to:
    (probably alternator like they said)
    11.5V: Almost 12, normal
    10.9 when running: some voltage is getting used by accesories but its not getting put back. My jeep gives about 16-17 volts when its running. Same thing happened to me about a year ago (I was only getting 9.2V or somthing when running) it was the alternator...
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    Jan 2004
    226
    this sucks, but it looks like I will be putting in a new alternator tommorrow night. I will have to look around for a cheaper place !
    Thanks for the help guys
    Mar 2004
    NE Indiana
    497
    IRON MAIDEN \m/
    Alternator- www.ebay.com
    Dec 2003
    SE PA
    683
    ALternator is shot. Check all your electrical connections (battery terminals, starter wires, solenoid connections, grounds, alternator wire), make sure they are all clean and tight. If they are, replace the alternator. You should see 14.2 to 14.6 volts at idle, turn all lights and accessories on and it shouldn't drop below 13.8v with a good alternator. Make sure your battery is charged up before running it with the new alternator. It's always a good idea to replace the regulator at the same time, if you have the extra $$. Many older fords had separate regulator, GMs had regulator built in to alternator (most vehicles are this way). Use a quality alternator. There are some cheapo remans out there, they are guaranteed to go bad again soon. Your Napa or Carquest store might sell brand new ones (not reman), they're a bit more expensive but worth it in my opinion. A bad alternator will leave you dead on the road.
    Jan 2004
    226
    Quote Originally Posted by bassman
    IRON MAIDEN \m/
    Won't be much help to have it running by tomorrow night
    CUYAHOGA FALLS, OHIO
    1,242
    battery
    12.66 is full charge on a battery. 12 is about 25%. this is with car off. anything under 12.44 you can start to get electrical issues. if you have a newer computer controled truck. good luck.
    max
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    most parts stores will test your alternator for you. I'd get one from a junkyard, I dont care for reman parts.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Aug 2004
    Ab, canada
    1,222
    Yeah most places will put your alternator on a growler and test it for you, but it sounds like you just need a new one.
    Rides:
    82 atc 200e
    83 atc 200e
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Vehicles have two power sources, the battery and the alternator. The battery is there to provide power to start the vehicle, the alternator provides power when the vehicles engine is running. The vehicle can run from both as well.
    Loosen both battery cables, start the truck, let it run and disconnect both cables from the battery. If the vehicle stops running; the alternator is bad and the vehicle was running of the power in the battery. If the vehicle keeps running, the alternator is good.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Jan 2004
    226
    Bought a 130amp and tossed that in, plenty of charge now.
    Thanks for the input guys
