Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 38mm Flatslide Mikuni
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    yes, it wont idle, getting way to much gas or something. it seems ok, not fine but ok in 4th and 5th from about 1/2 to 3/4 throttle, but after that you dont gain much.
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    Newfoundland
    5,280
    Ok well your pilot jet is where you need to start, try goin down a size. If that helps but its not perfect at 1/4 throttle then go down one more. To help between 1/4 to 3/4 throttle you need to adjust the needle clip. If its rich move the clip up, if its lean then move it down. The wide open throttle is handled by the main jet. If you spit and sputter on wide open throttle then you need a larger main. I suggest doing some plug chops at different throttle locations to see where you need to make adjustments. A plug cop is just riding at one throttle position for 30 seconds then kill the motor and grab the clutch and stop. Make sure you do not close the throttle until the bike is shut off completely. Remove the plug and check to see if its black(rich), tan(perfect) or white(lean).
    May 2003
    556
    ill try this, thanks for all the info. ill be working on it sometime this weekend if not before. ill let you know how it goes, and probably have more questions. thanks
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
