Thread: Question on Paul Turner ATC 250R Pipe
    markdb420's Avatar
    markdb420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Virginia Beach, VA
    413
    I just bought a used PT High Rev Pipe, and was looking it over and it has an odd mount up near the front of the pipe and there is no mount in the middle of the pipe like normal other pipes. How would I mount it. It looks like I could use the motor mount area to mount pipe. Maybe it is just a different setup and maybe I don't even need to mount it if it makes a tight connection with the silencer. I will try and get a picture on tomorrow. Thanks
    06 Yamaha Bruin 4x4
    04 TRX Rancher 400 AT 4x4 GScape
    86 ATC 250es Big Red
    84 ATC 200s (31 yrs running strong)
    13 F150 4x4 SuperCrew 5.0
    00 Excursion V-10 lifted with 35s
    ____________________________
    Gone
    07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
    Aug 2004
    East Central, Missouri
    546
    Question Could that be a TRX250R pipe?
    Don't TRX250R pipes have the different mount point as well as a different angle of the outlet of the expansion chamber??
    Mar 2004
    North Central Ohio!!
    2,712
    Use your old exhaust mount down at your motor mount. Bolts right up and provides extra stability.
    markdb420's Avatar
    May 2003
    Virginia Beach, VA
    413
    Derrick that is what I was thinking. It looks like it'd bolt directly to the motor mount area. Thanks. I cannot wait to get this thing on! Went to see the sandblasted frame and drop off all the little parts that were forgotten when the 3 wheeler frame was dropped at the painters. Did some resto work to my Bayou, new OEM front bumper, and grill. My 86 250r will be something different on a 86 250r. Well, like I say I'll take that advice and Git R Done!
    06 Yamaha Bruin 4x4
    Gone
    markdb420's Avatar
    May 2003
    Virginia Beach, VA
    413
    Here is the picture of the mount.
    06 Yamaha Bruin 4x4
    Gone
    3leggeddog's Avatar
    Nov 2004
    you want to use the bottom motor mount bolt,and make sure you leave it loose on the frame so you can move it around to start the bolt into the pipe.your definitly gonna want to jet it,i called duncan racing and they were within 1 jet size.
