Results 1 to 7 of 7
Thread: Picking up an 87 TRX250R
    Feb 2003
    485
    I am picking up a 1987 Honda TRX 250R in a few days. Before I go look at this, is there anything in perticular that I should be on the look out for. What I know about the machine. Motor was rebuilt less tha 4 hours of ride time ago. It basically is just past break in. Has all receipts for work done on motor. Machine has not been driven in around 1 year. After motor rebuild, machine had brake issues. I will need to find either front or rear brake parts to fix. Has orginal beat up plastics as well as new still in package plastics.
    I am getting this 3rd person from a friend who set up the meet for the more than likely sale. I will know more after actually seeing the machine. I do not know whta I will end up paying if I get it, but I do know that the current owner is asking less than what I paid for either my 85 350X or my 85 250R.
    Any words of advice or any good places to find parts besides EGAY. I always have dealt with trikes on the rebuild end. My 4 wheelers are year 2000 and newer so I never had to look for old parts.
    Thanks,
    Dave
    Michigan
    1,220
    Check the left case for damage, drain plug, rear axle bearings, front wheel bearings, a-arm bushings. Ask if its had the clutch update kit. You can get caliper, and master rebuild kits from service honda. If your getting it really cheap you can expect to have to replace some bearings and seals. I would be more concerned with the motor and the frame. Look for cracks and bends. Stand it up on the grab bar, stand back and look at the undercarage, if it leans to the left or right it has serious frame issues. These quads are about the easyest to work on and are becoming alot cheaper to buy since the 450 came out. Parts are plentiful for these old machines.
    Feb 2003
    485
    Well here are pics of the $700ish 250R I picked up. I now need help in finding items for this machine. I never needed to look for Quad parts so an advice is helpful. I need the following:
    Headlight
    Tail light
    Wire harness
    Control switch
    Air box lid
    Thumd throttle and cable(has twist cable)
    Front calipers and master cylinder
    Oem exhaust
    The swinger does not appear to be OEM. It has stickers that say Westcoast and its white. Not sure if its been painted and stickers affixed.
    The motor is all intact with 8/10 hours on a .080 bore. I tested to over 190PSI with a bad tester.
    The case is also 100% intact without the typical slung chain issue. The frame does not appear tweaked and its not cracked. A motor mount was damaged, but repaired at some point. All bushing and bearing are basically new.
    So what do you think? I also have been offered a 1999 TRX 250R that is not as nice, but complete.
    May 2002
    Cortland, NY
    1,195
    Looks like you got a good deal for $700.
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    Nov 2002
    Kirkville, NY
    3,831
    Very nice! It looks like you got a great deal.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    2strokepwer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Mississippi
    359
    what kind of pipe is that? never mind, i see now
    2 strokes feel the power
    Feb 2003
    485
    Quote Originally Posted by 2strokepwer
    Its a PSI pipe with unknown silencer.
