Results 16 to 30 of 51
Thread: How to power valve your Tri-Z
    Apollo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Fort Worth, Texas
    190
    Man, that is an awsome thread. I love technical stuff.
    Mar 2004
    North Central Ohio!!
    2,712
    I received my new piston kit today. The rest of the parts should be in by friday, so i'll add to this post sometime this weekend.
    Mar 2004
    2,712
    Ok. Here's the cylinder installed. Notice the vacuum port installed in the cylinder for the fuel pump. I chose to use a standard threaded one from Napa, just tapped it and screwed it in.
    Mar 2004
    2,712
    Now here's the first real "Problem" I've ran into.
    My engine didn't come with an intake or reedcage, so I picked one up on ebay...well this is supposedly off an 83, which obviously won't work on the 87. (the intake would fit but there was NO WAY that reed cage was fitting!)
    Next Picture: Here's my quick solution. I carved an adapter out of some plate aluminum and just reused the stock Tri-Z intake and reed cage. Wonder how it will work with the boost box hooked up?!?
    Last Picture: Here's another shot of the adapter. I will probably move this to my trail bike later and use something else on this bike. You can see in the picture the nest issue of fitting a filter on the carb!
    I'll finish up the engine on Monday. Watch for more pics.
    Attached Thumbnails Attached Thumbnails Powervalve 11.jpg   Powervalve 12.jpg   Powervalve 13.jpg
    Front royal, va
    2,186
    ill buy that part from you , the 83, like mine, has that huge 8 petal reed cage, and a 38-40mm carb willl not fit in the little 32mm intake,if it does by chance, be forewarned, you WILL run lean on top end,even with a 580 main!
    Mar 2004
    2,712
    What's the theory behind the intake making the engine run lean? I'm running a 37mm in the stock intake right now with no issues. I'll keep that in mind, but I'm going to see if it fits in my other engine first. I may be able to just switch them around.
    I can see right now, that a custom intake will have to be built to run the stock airbox set-up on the trail bike. That thing is seriously kicked over to the left.
    Front royal, va
    2,186
    i see , i thought you might have a 32mm carb going on that intake, a 37 will be fine
    Mar 2004
    2,712
    Just an update. I fired the bike friday night, seemed to run fine. Today I did a soft 1/2hr ride to break in the rings and it seems to be doing well. I'm working on getting an air filter installed and will post up some more pictures tomorrow. I have had 2 intakes on it now. Still not satisfied so I am going to build a custom aluminum one, soon.
    Mar 2004
    2,712
    Here's the last two pictures of the air filter and adaptor I went with.
    All in all, I spent $250 total on the engine swap, and don't feel it was a worthwhile investment. I guess it really only cost me about $150 extra, because I needed to freshen the top end anyhow.
    I wouldn't recommend spending extra cash just to do this swap, because it really didn't show me any performance gains. Unless something changes it was a big disappointment.
    I already had the DG pipe and silencer, 36mm carb, Uni filter, and Boyessen reeds. Everything stayed the same with the exeption of the powervalve topend and it feels the same.
    The only thing left to try would be to swap the flywheel, as the Tri-Z flywheel is huge compared to the YZ.
    This thread is officially done!
    Front royal, va
    2,186
    thats very odd... they have 8 hp more than a stock z, maybe the 83 motor like mine has more hp, i noticed a night and day difference, my stock motored z had a new top end and i went up two teeth on the front sprocket with the powervalved z , and the powervavled z still out runs the stock z on bottom end pull and alot more on top, you must not have it dialed in right, i run a 40.5 mm carb, i tried a 38mm, and it had NO POWER!!
    Mar 2003
    Kansas
    1,507
    Yeah man, you got something seriously wrong. My 87 is almost completly stock, and it will walk all over most anything its up against (besides all out high dollar drag banshees)
    I agree with 03 orange shee, you dont have something dialed in right. I was running a 38mm carb on mine, but it also has the pvl style ignition.
    My Z with the 87 YZ motor is a good 10-12 bike lengths ahead of a stock 85 Z in the 300 ft drag races... if your not seeing the same, you got something not working correctly.
    Aug 2004
    Ab Canada
    4,368
    so 03 orangeshee...is yours an 87 top end then?
    1985 Tri-Z-
    Mar 2004
    2,712
    Here's what i'm saying guys, I only changed to the powervalve set-up. Nothing else. So it's probable that the whole YZ engine has many different benifits over the Tri-Z, not all in the powervalve assembly. I think that I'll switch to a bigger carb next, since that's an easy swap. Then i'll try the flywheel/ ignition swap.
    Brandon and I are going to go race them today, so i'll have a better idea. Before his R and my Z were dead even. It was 50/50. 10-12 bike lengths in 300 ft is HUGE! I'm sure I would be able to feel that. I'll let you know how that goes, as well as any differences in carb swaps and flywheel/ignition swaps. Then we'll know exactly where all the power is coming from.
    Mar 2003
    Kansas
    1,507
    Quote Originally Posted by Derrick Adams
    Oh yeah, you'll be able to feel it!! And your face will show it!! The smile will be permanent for a few days... If all else fails, yank that top end off, and drop that YZ motor in like I said you should of in the first place. If it still runs like the Z motor, something is messed with the top end.
  15. #30
    Front royal, va
    2,186
    mine is a 83 stock yz motor, no porting what so ever, and like chainsaw says, very big grin on your face after riding, it feels like i went from a blaster to a banshee, there is that much difference, 8 hp is alot on a light three wheeler 32 vs. 40 , i went up two teeth on the front sprocket(15/40) and it i still cant keep the front end down through 4th unless i let off the gas , the 13 tooth has too much tire spin, or i couldnt crack it for fear of flipping over backwards
