Results 1 to 3 of 3
Thread: Need advice on Tri-Moto 200 problems?????
    CENTRAL NY
    1,709
    It strated as a broke cam chain. I pulled the motor apart put the new chain in. Set the timing as I assume as right (set the fly wheel on the F and lined the mark on the top gear w/ the mark on the top of the head). Put it all back together and it fired up on the 3rd pull. Rode it around the house a few times, pulled it in to change the oil (clean out whatever could have possibly gotten in the motor from being apart). Now it wont start, I checked the timing its off 180 degrees? When I rode it around it sounded like the tenshioner was to tight, so when I changed the oil I backed it off and the chain was still pretty damn thight?
    What am I missing here? If the key way sheared off the cam, the valves wouldnt open right?
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Nov 2002
    1,189
    the thing should be on t, not f. f is for fire, t for timimg, remeber, it is a four stroke, so the cam turns once when the cranks turns twice, so it would be 180 degrees off. think it as this, it goes up, exhaust, back down, intake from carb, up again, compression, down compression, up exhaust.... so you can see that the cam has to turn half as much as the crank as far as the timing chain, is it noisy? try loosening the bolt some more and running it, sometimes the tensioner gets stuck after siting for a while.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    CENTRAL NY
    1,709
    A simple case of rushing over, 7th grade Technology class mechanics... :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
    Thanks for pointing out my stupidity!!
    2001 TRX90
    1984 ATC70 Pit bike
    1984 110 for sale
