Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: extended axle, or wheel spacers??
    Jul 2003
    Ontario Canada
    813
    Oldschoolin,
    Do you know if the jug off it will fit?? If so, then i will be a happy boy, lol
    Curtis
    Currently Trikeless- but I have a LT250R
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    In my Feb of dirtwheels, it says the 81 250r is essentially a cr250 engine with with a bigger flywheel and smaller carb, so I guess that means that the engine is the same as the 81-82 cr's, since the 81and82 250R's were the same right? I wouldnt take that to heart, unless you can get the top end for fairly cheap, I am sure thst someone on here knows for sure though.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by honda200
    Oldschoolin,
    Curtis
    I wish I knew but even if it did you still need a lot more than a jug to make a motor liquid. I'm pretty sure the case halves would be different and you'd still need a way to pump the water. From what I hear the air-cooled R's do really well without liquid cooling anyway. Sorry I don't have much for ya.
    May 2002
    3,658
    Quote Originally Posted by Tri-Z Pilot
    Go to www.powersportspro.com and look up the 81-82 CR250, you'll see they are very different motors.
    Central PA
    1,952
    I think he want's to know if an air cooled cr jug will work on the aircooled 81-82R.
    PastRides
    SOON MY PRECIOUS!
    May 2002
    3,658
    lol, they didn't make an air cooled cr250 in 81-82.
    Central PA
    1,952
    Are you sure? Dirtwheels said they did, I dont know much about bike statistics, maybe they meant 1980cr since the 81R's came out in 1980?
    PastRides
    SOON MY PRECIOUS!
    Newfoundland
    5,280
    So your going to keep the 82? The 84 is an all around better bike then the 82 in every aspect. Both are aircooled, only the 85/86 Rs are liquid cooled.
    Jun 2003
    South of Rochester, NY
    3,471
    A 84 tank will NOT fit a 82 frame BTW...
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Feb 2003
    Australia
    927
    I wouldn't believe anything Dirtwheels says. They are just as dumb about trikes as they were 25 years ago.
    Central PA
    1,952
    Come on, I know they had aircooled cr250's around the late 70's early 80's, I dont know if the jugs will bolt up, but if you get the parts cheap, it's worth a try.
    PastRides
    SOON MY PRECIOUS!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I have the Dura Blue 2.5" wheel spacers on my Tri Moto what a differance it has made in handling.
