Results 1 to 8 of 8
Thread: any trike shocks fit on a warrior?
    Oswego, IL
    1,858
    buddy needs a new warrior shock wondering if a z shock would work, its a 96 warrior.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Aug 2002
    NY
    2,652
    i am sure a tri-z shock will work but good luck finding a good usable tri-z shock cheap. just get another warrior shock off ebay
    SE Minnesota
    533
    huh?
    I'm in complete awwww. If you are actually thinking about taking a rare trike part to fix a crappy(cheap) quad part, I suggest you impose a 1 week suspension from all three wheeler sites on yourself. You need some time off to think about what you did here young man.
    83 YT 175
    85 ALT 125
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Well, if people use warrior shocks on Z's, then you can use Z shocks on warriors I suppose. The reason people use warrior shocks though is because Z shocks are hard to come by, expensive, and non-rebuildable, just look for a warrior shock.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Oswego, IL
    1,858
    the older warrior shcoks arnt rebuildable either. im jsut trying to find out what shocks fit so Dan Tenn dotn respond to a post if dont got an answer or an idea. how do your response help me at all? im looking at my options. i dont care if they are rare if i find one for cheep ide probly tell my friend. ok so anyone no any shocks that will work on the warrior? raptor? shee? honda shocks?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Washingtons Crossing, Pa.
    2,977
    ... he was just kidding you vartiak15 ....... He does bring up a good point though - in theory, its next to impossible to find a "good" Tri-Z rear shock - but there are probably thousands of good warrior shocks out there, and cheap I might add - so I would just shoot for that. If hes looking for performance, try a new Works.
    Oswego, IL
    1,858
    ya lots of warrior shocks. how do i no if any of them are good. or if they are just like his. how can u really tell if u need a new one? he says b/c he can lift up the back a lil and it will just sag down. it wont stay. any way to really test a shock?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    2,977
    You can take it to any dealer and they will test it - the truth is - if its dampening the springs movement in both compression and rebound ... its still basically working. I would try adjusting the pre-load nut to a heavier setting to see if that helps.
