Results 1 to 2 of 2
Thread: Dang New High rev pipe!!!
    markdb420's Avatar
    markdb420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Virginia Beach, VA
    413
    Went and put the PT High Rev pipe on and WHAT A FREAKIN DIFFERENCE! Only thing is now I need to find a better head for the LA Sleeve Big bore cylinder. I had this happen before where the water inlet on top of the stock type cylinder head pops up and begins leaking. I had this head machined to fit the 72mm sleeve and was using the Cometic gasket kit for this application. This is the 2nd head to have the same thing happen, and this is on two different rebuilds. I am wondering if someone knows where to purchase a cool head type head that is billet to eliminate this problem that I am having. Any help will be most appreciated!
    06 Yamaha Bruin 4x4
    04 TRX Rancher 400 AT 4x4 GScape
    86 ATC 250es Big Red
    84 ATC 200s (31 yrs running strong)
    13 F150 4x4 SuperCrew 5.0
    00 Excursion V-10 lifted with 35s
    ____________________________
    Gone
    07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
    Michigan
    1,220
    Paul turner and ESR both have the cool heads available for the big bore. I'm sure there are others as well.
