Results 1 to 15 of 16
Thread: 350X Top speeds?
    NE Arkansas
    2,344
    350X Top speeds?
    What would the approximate top speed be with 18's vs 20's on a 350X? on an R?
    later
    Trav
    My Rags
    Mar 2003
    Barnesville,Ohio
    2,298
    350x-
    20's-65
    18's-66
    250r-
    20's-67
    18's-68
    lol
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Warsaw, IL
    862
    A 350X with 20 inch tires will do about 55 MPH
    With 18's it will do about 50MPH
    1969 Trail 70
    1973 ATC 70
    1983 ATC 70
    1986 ATC350X
    1986 ATC250R X 3
    1986 ATC200X
    1987 ATC200X
    2012 Polaris RZR
    Washingtons Crossing, Pa.
    2,977
    ... who cares ... its how quickly you get there that matters.
    Dec 2002
    Janesville,WI
    573
    Quote Originally Posted by Wickedfinger
    Maybe he doesn't know...that's why he asked Also,trikerider,you have it backwards.Running 20's will get you a higher top speed than 18's
    85/86 ATC 567x
    Bailey(11/30/97-4/17/06) My little angel
    HRC1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2004
    michigan
    151
    NE Arkansas
    2,344
    i care!!!and i wanted to know, that's why, i understand that acceleration is more important than top speed,,,
    My Rags
    NE Arkansas
    2,344
    Quote Originally Posted by HRC1
    thank you for your useful reply,,,is 8250 the proper rpm to use, the reason i ask is cause i have used that same calculator on my 400EX after i have checked it with my gps and gotten totally different top speeds,,,i know that the calculator is in the ball park,,,thanks alot
    My Rags
    May 2004
    michigan
    151
    Quote Originally Posted by TravEX
    I'm not sure, i could check my shop manual and see what redline is, but i dont know if top speed comes at peak tq or hp, they tend to drop off after the tq peak and feel slower. It's probably close enough for a stock bike.
    Jan 2005
    las vegas nevada
    157
    My 85 with 20in klaws and stock gearing a pipe and filter toped out at 65m.p.h i raced my cuz in his hyndia
    Oswego, IL
    1,858
    what is the rpm's the 200x uses?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    May 2004
    michigan
    151
    Quote Originally Posted by vartiak15
    Elaborate on what u mean. for a gearing calculator? I havent found one for the 200x but i never really looked either. The calculator doesent work off just rpm.
    Mar 2008
    Tug Hill
    1,282
    i bought a nos 350x engine and just broke in it did 65 on a bushnell radar gun(same model cops use) with stock rear tires and gearing. with 20's you would be lucky to hit 60 depending on if they were rounded tires or flat
    PA
    3,515
    Quote Originally Posted by Tyler 54 View Post
    maybe with stock gearing but who keeps the gearing stock after going to 18s?
    with 18s and 14/36 gearing my 350rx was clocked at 65mph....and this is my low gearing.
    WWW.HREATV.COM
    Santa Barbara, California
    1,161
    It also depends on if the 350x is a piece or not.....
    1985 Honda 200x
