Results 1 to 7 of 7
Thread: Broken bolt
    Mar 2004
    Gettysburg PA
    498
    Broken bolt
    Iwas installing my exhuast on my r yesterday but i lost one of the exhuast flange bolts. so i went to walmart and bought a little box with like 4 or five of them. well i put it in and when i got the bolt about half way threw the dang thigh broke off inside i wasnt even putting that much preasure on it. could it have been a bad bolt, cold weather or a combonation of both? i was wondering what i should do now? do i have to go get it drilled out and re tapped?
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    I strongly suggest avoiding buying hardware items at Wally World
    Maybe the threads didn't match? Did it bottom out in the head??
    Bill X_R is offline Bill "The Finger" XR oo|oo Arm chair racerJust too addicted
    Feb 2003
    Cincinnati, OH
    672
    The best thing to IMO. Is drill out the bolt with a bit that is just smaller than the OD of the threads of the bolt that broke. You have to be very careful, then run a bottoming tap through it.
    86' 250 R
    02' DS 650
    03' Cannibal
    03' Haspin Vet
    04' Haspin Vet
    05' Haspin Vet
    Alberta, Canada
    215
    Could use one of these. They require less technical knowledge than tapping without the danger of damaging the original threads. Your local hardware or automotive store will have sets containing different sizes.
    I got a set of five spiral sizes for around $15 Can.
    Mar 2004
    Gettysburg PA
    498
    i did drill it out and tried to take it out with one of them bits you guys are talking about with the reverse threads and that also broke of inside. i havnt tried to drill that out as well but im not sure if im going to be able to or not. i think its pretty hard metal?
    My Trikes
    1985 250sx
    1986 250r
    Feb 2003
    Cincinnati, OH
    672
    Quote Originally Posted by 85 250sx
    Ewww the EZ out broke? Tuff break (no pun intenended) I've had that happen to me trailprotrailpro. Those things are pretty hard, you might be able to shatter it with a punch, or are you lucky enough that there is nothing behind the broken bolt? If so the puch should push it right out. If you can get it out I would still recomend going up in size with the drill bit untill the remaining pieces just fall out. Then run a tap down the hole.
    86' 250 R
    02' DS 650
    03' Cannibal
    03' Haspin Vet
    04' Haspin Vet
    05' Haspin Vet
    Mar 2004
    Gettysburg PA
    498
    i wish i could just use a puch but i cant i didint drill threw the whole bolt just enough for the EZ out to fit good. the EZ out that broke off woubles around but i cant pull it out and cant get any plyers or anything onto it to get it either how frustaiting
    My Trikes
    1985 250sx
    1986 250r
