Thread: atc110 nearly there
    Jan 2005
    Derbyshire ENGLAND
    39
    atc110 nearly there
    I got my 110 trike back together last night after the problems i had getting a spark, I was suprised when it fired up almost straight away, It ran fine once it had warmed up abit but when i came to select a gear to ride off it wouldnt go into gear it just sounded like it was between gears (an awful sound) so i stopped the engine put it in gear and push started it, when i did this it ran fine but still wouldn't change gear, I stopped it and tried it in all the gears which work if i put it in the gear i want before i start it. I need to get this sorted because it was so much fun riding it.
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    Remove the clutch cover and inspect. You will find something tha wont be assembled correctly. Or try adjusting the clutch. See the adjustments in the side of the cover?
    Shrewsbury, West Virginia
    564
    The clutch needs to be adjusted. The adjusting screw is on the right side of the engine.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    564
    Woops, I didn't see HaggLE's post. He pretty much explained where the problem is at.
    '82 Honda ATC 110
    Jan 2005
    Derbyshire ENGLAND
    39
    Thanks alot guys i'll try this out over the weekend and let you know how I get on
