Fuel Economy
In my classes we are getting a 6hp briggs motor. you get 150ml of gas and you have to make it run the longest. the only limitation to the contest is that you cannot alter the block, but anything else goes. what would you suggest on doing? anyone know the briggs motors? we have a 3.5hp motor apart and wondering if the cams are the same, it would be like a really really mild cam, could this work? any ideas? thanks
85 Tri-z
38mm Flatslide
Boysen Power Reeds
DG Pipe and Silencer
Bored 1.25mm over
Wiesco Pistion and Rings
K&N Clamp on Filter
Compleating Restoration
