IM HAVIN A PROBLEM WITH MY QUAD THE BIKE IS LEAKIN COOLANT INTO THE OIL.. IVE TRIED REPLACING THE WATER PUMP AND MECHANICAL SEAL, THE HEAD GASKET... THE BIKE IS STILL CONSUMING COOLANT, AND BUILDING UP PRESSURE IN THE RESEVOIR... COOLANT IS SCREAMIN OUT OF THE OVERFLOW HOSE...? THE BIKE RIDES FINE BUT I HAVE TO KEEP PUTTIN COOLANT IN THE BIKE?
HOW ELSE COULD COOLANT GET INSIDE THE CRANKCASE... BY THE WAY ITS ALSO SHEDDIN WATER PUMP IMPELLERS? ROUNDIN THEM OUT COMPLETLY... WAT CUASES THIS ON THE 87 MODEL?
WEREC OULD I FIND USED PARTS MAYBE I COULD FIND SOME USED PARTS MAYBE ITS THE RIGHT HAND COVER THAT IS BAD? THE PART WERE THE SEALS ACTUALLY SEAT AT?![]()
YOUR HELP IS GREATLY APPRECIATED...
