Results 1 to 9 of 9
Thread: Valve adjustment?
    Jan 2005
    Miami, Fl
    15
    Question Valve adjustment?
    Does anyone have the spec's on the spacing for the valves on an 86' 350x? intake/ exhaust?
    Jan 2005
    Miami, Fl
    15
    Thanks for the info
    Jan 2005
    Miami, Fl
    15
    Jeswinehart, do you also know about jetting? if so what is the main jet suppose to be screw in till? approx how many turns or is it suppose to go even with the bowl????? also if Im in Miami fl where its tropical the jet on the slide should be in which position from up toward leaner or toward richer?
    Jan 2005
    western Pa
    79
    screw?
    Are you sure you're not talking about the air to fuel screw? If so I usally turn it in the whole way( be careful) then back out a turn and a half. This is my starting point for setting a carb. After that you then just have to fiddle with it till the bike runs the way you want it. just turn it 1/4 turn at a time.
    Check out my new listings....Lots of new stuff
    http://motors.search.ebay.com/_W0QQsassZjlurch
    Jan 2005
    Miami, Fl
    15
    im refering to the jet inside the carb when the bowl is removed , the one with a nut on it...and the other one inside the slide that you can adjust the clip to make it leaner or richer.....Im not sure how far down the one inside the bowl should be since I took apart the entire carb to clean it up.
    Jan 2005
    western Pa
    79
    sorry
    o ok sorry not sure I understand...maybe a pic ..
    Jan 2005
    Miami, Fl
    15
    when your looking at the bottom of the carb there is a screw with an oring to drain the gas out of the carb right under that is another nut with a washer if you were to remove that you can see the jet I'm taking about, and the other is in the top of tyhe carb when you look threw the middle you can see the needle jet thats the one you move the clip to make richer or leaner. hope someone can help me with adjusting both of these jets.
    Jan 2005
    Michigan
    135
    the main jet sould be tightened till it seats ( snug it ) not adjustable you just change them
    needle position is 3rd groove for stock clip position
    Jan 2005
    Miami, Fl
    15
    Talking
    thanks for the info my 350x is running smooth and with no [problem starting up....kicks right up on 1st or 2nd kick
