Results 1 to 15 of 20
Thread: 185s not starting or trying!
    Jun 2004
    Brazil, Indiana
    1,389
    well i put the 200x head and new stator on today..now it sounds like it has an airleak somewere..but i cant find any..it also doesnt even try to run..no spark or anything..do i have to put the 185 head back on or something? someone please help..im really stuck on this thing...or maybe i didnt solder the wire to the stator good enough or something but i dunno it just aint working..its really starting to p!$$ me off!!!
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Jun 2004
    Brazil, Indiana
    1,389
    no one can help? thats wierd.,.most of the time people jump right on it
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    You have a new stator in the bottom? Where did it come from? why did you have to solder? Seems like the problem is there if you have no spark.
    Jun 2004
    Brazil, Indiana
    1,389
    new stator is from hyperparts.com ... they are 13.95 or somethin like that...its a stator coil..not whole assembly..and i had to solder the wire to the new stator coil..u have to or it will NOT work at all..but im thinkin thats my problem agian..maybe the solder cam off or something..im going to go buy some good solder and order a flywheel puller and see whats gonna happen!..lol
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Use soldering flux and 60/40 solder for a nice solid connection and then cover the connection with shrink tubing.
    Jan 2005
    330
    make sure that the insulation can resist high heats because it gets hot down there.
    Jun 2004
    Brazil, Indiana
    1,389
    well i was using flux core solder but it doesnt melt well..for some reason..and what do u mean by shrink tubing?? melt some plastic over it?
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    Jan 2005
    330
    You can buy stuff from electronic stores that is a thermo plastic. Heat it and it shrinks and covers your wire.... I wonder why they call it shrink tube???
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by 83185s
    I bet your soldering iron is not hot enough causing a cold solder.
    You know how many watts it is?
    Jun 2004
    Brazil, Indiana
    1,389
    no but its old..im going to try the other when i get my flywheel off again... i get a new puller monday so...either i wait or i have the shop do it again..i prolly have the shop do it saturday tho...BTW i got my new parts in..wiseco rings for my piston, full gasket kit, cam chain guide and tensioner, heavy duty cam chain (D.I.D) and a few others..i must say that the stuff i got doesnt even look like its worth 130 bucks..lol
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    crackshot's Avatar
    Idaho
    1,024
    Probably run for 50 years with all that new stuff!
    Jun 2004
    Brazil, Indiana
    1,389
    trailprotrailprotrailprotrailpro i wish it ran! lol...i got it all torn down to the case in my garage in about 2 hours..gettin ready to take the clutch off so i can remove the counter shaft and put a new one in and a new shift shaft and rod..the shifter and the front sprocket are welded to the shafts ..and the new sprocket is a 13 tooth..o yea...and hopefully i can put the 200x gearing in there so i can be just as fast as a normal 200x but with an anuto matic clutch..the downside is takepff but i dont plan on racing so its all good..unless im already moving and decided to smoke my bro on his lakota sport 300...lol that would be great!
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    crackshot's Avatar
    Idaho
    1,024
    After a rebuild, it seems that you have to work out the bugs. Usually it is something simple too!
    Jun 2004
    Brazil, Indiana
    1,389
    yea i know...i tell u what tho..after 20 years when a honda locks the piston to the cylinder and melts the rings..u always have a problem..before my friend locked it up it ran great all the time..never failed to start on the 1st or 2nd pull...even without the choke in the winter with wind chills to -10...it always started before that..now that i rebuilt it..it dont work..and i found my problem i think with the air leak noise..my exhaust valve is still open when its supposed to be closed..so thats a simple fix..now if i can just get the stator fixed..itll be perfect...and 1 ? on my stator u said use shrink tubing right? well should i only do the connection or should i cover the whole stator coil with it and the connection??
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    crackshot's Avatar
    Idaho
    1,024
    I would just cover the connection where you soldered it.
    How did you friend melt down your motor? Ride the piss outta it?
