Well, I just paid 25$ something for some stinking bulbs for my X and they just Blew, I am pretty ticked right now. does anyone know what could cause this?
Were they 6 volt or 12 bolt bulbs? what wattage.
I seriously dont know. The guy I bought them from, pulled them from a brande new Headlight off the shelf.
The 350x's have a special headlight for them and them only as far as I know.
does the tail light work.
I had this issue once and the regukator was shot.
Signature:
1985 ATC350X
1986 TRX-250R(Soon to be an 87)
2001 Polaris Scrambler 90
2004 Arctic Cat DVX400
2003 Yamaha Blaster
2005 YFZ450
Rip: To many to list........
nope, It did work, But I paid less for the whole tailight then I did for each headlight thats why i am grumpy about that, plus those bulbs are easier to come by. I may try to rig some in.... Oh I am so mad
Hey $25 bucks thats nothing try $400 for a pair of 125 tri motos thats what i got into mine and their in a pile in my barn now thats money down the drain cause even if i fix them up their only 125s also my buddy has fog lights(i think ) from a ealry 90s chevy truck for lights on his 350
1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
1981 trimoto 125
1971 suzuki ts 185 it will spank a 200x
1966 gmc 3/4 ton
Probably a voltage regulator problem. A lot of people over look this and blow a set or 2 of bulbs before realizing there is other issues.
Bulbs? I can get non-halogen ( sp? ) bulbs a lot cheaper than $25. If you need some let me know.
Howdy
Will they work in a 350x? I ask because I am sure they have thier own special bulb.Originally Posted by Howdy
I remember seeing a post where somebody got 350X replacement bulbs from Dennis Kirk for $3 to 5 each. However I think they are a 25W bulb while the OEM 350X bulb is 35/36.5W. Still, cheaper than the (I think) $20 each that Service Honda wants for em
How long did it take for the bulbs to blow?![]()
the volatage regulator is mounted on the backside of the airbox. i think it's the white + green wires . the other 2 are for the tail light.
( 4 wires going back towards the rear of your trike )
i was working on my x once and forgot to plug in the regulator - POP went 2 halogens ,,,, it took a few extra revs to get the cheap tail light bulb to pop.
john
I swear i cannot find the bulbs on the DennisKirk site. Maybe I should try calling.
The light blew in under a minute. They got all blue (Projected against the wall) and then bam, out and some smoke.
I think my regulator only has 3 wires coming out of it, and 2 are hooked up. I will have to look better
Yes, they fit in the 350x. I have been running this style bulbs in my 350x's for years. I would rather blow a couple $3 bulbs than a $20 one. But as mad_max stated they are 35watt bulbs. They aren't quite as bright as a halogen, but they are faily close. I'm not sure how many I have in stock but I do try to keep a half a dozen or so. I am thinking they run $2.75 a bulb. I will need to double check this toi be sure.Originally Posted by 02blzrx
I checked denniskirks web site and I couldn't find them either. I know they had them before. hmmm
Howdy
Hmm how do I test this regulator, im blowing bulbs as well.
www.3wheeler.org
* * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
Put a volt meter on a hot light feed wire. Start the motor. Watch the voltage and rev the motor. If it takes a huge jump, your regulator is not working.
you know what I looked at one on ebay, ity had 2 wires and what I believe was a ground anttached to a bracket that grounds the the frame. Mine doesnt have that. So I figure that my surges of power have no where to be distributed to. Or is the one in the picture nit for a 350x?
Could someone please take a gander at it.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
mine has the same two green and white wires.
