Results 1 to 9 of 9
Thread: anyone ever had an clutch "grab" too much?
    Brandon, Manitoba
    2,209
    i just put my motor back together the other day, when i reassembled the secondary clutch, i lubed it up with transmission oil. Now ive got it together, i put it in gear and and it starts moving. its like the clutch is sticking or something.
    Nov 2002
    Kirkville, NY
    3,831
    Is the idle set too high?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Brandon, Manitoba
    2,209
    nope, it idles normal. maybe if i took the clutch off and cleaned all the parts in solvent, re lubed it and put it back on, maybe that will work.
    thefox, you sure know a lot about YTM's every question i have your usually the one to answer. thanks!
    hey, those are made to use oil, the atf is made to not slip, so you may want to just drain it and put in fresh oil.
    one cylinder is not enough!!
    Nov 2002
    Kirkville, NY
    3,831
    If you did use atf then you might want to try cleaning then off like 4cylinders, said if that is not it I don't know what else to suggest.
    I have worked on a few tri-motos so I can picture the insides of the engine fairly well. I am surprised that more people don't respond to your questions, the Yamaha trikes are not that much different then the Hondas.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Brandon, Manitoba
    2,209
    i used manual trans oil, thats what the manual called for, well actually just trans oil it said
    hey, do you have a service manual? what does it say to use? It should give a weight. most bikes use like 10w-40 motor oil. If you used gl80-90 it's going to be a little trickey.
    Brandon, Manitoba
    2,209
    it says in the manual...
    CAUTION
    If either or both friction plates have been replaced with new ones or if they were cleaned, apply new clutch/transmission oil to all plate surfaces. This will prevent the plates from burning up when used for the first time.
    it doesnt give any weight to use.
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Well everything I have read and been told says that in most cases you wont to use ATV or Motorcycle oil for wet clutch applications. Regular oil has anti wear inhibitors that can cause the clutch to slip and not grab. TimSR can prob give you a good answer to your problem. Im betting that the oil you have put in is too thick which casues the plates to have excessive build up on them and therefore making continuous contact. Manual tranny oils viscosity is way different than motor oil. Do the yamahas have seperate fill points for the tranny and engine? I know that hondas dont.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
