Thread: Would it be so hard to do ???
    Jul 2004
    Mud hill. close to water !
    3,658
    My sx has a really bad pipe.. actually it's good until it exists the frame but the expanded part with the core is totally rusted out.
    My neighbor owns a sheet metal shop, has access to sheet stainless steel, in whatever thickness.. tig, mig, flux core, etc.. welders, pipe bender etc...
    Would it be a bad idea to try and make one based on the original desing? Any improvments one could make over original ? etc... materials to use instead of stainless ? ( would be heavy... )
    anyone ?
    Currently :
    Jun 2004
    potsdam ny
    1,227
    should be pretty easy, just follow the original design exactly, and use the baffle system out of your current muffler...stainless is good, just use thin sheet metal like 22 ga. or maybe little bigger idk, use some common sense and follow the original as close as possible and you should have a sweet pipe....
    p.s. dont use a pipe bender, use a mandrel tubing bender or you will kink the crap out of your stainless tubing and it will look and work crappy...
    Jul 2004
    3,658
    I was talking to him about it last night.. he was taling about making a cover for it, keeping the original, but covering it in new metal.... ( i'm not too crazy about this, adds twice the weight , and leaves a rusted p.o.s still attached to my ride.
    The baffle is loose in there right now, and just jumps around, so i'll have to cut it open and figure that out somehow. should it covered in packing ? or is that a 2 storke thing ?
    Currently :
    Jan 2005
    Spruce Head Island, Maine
    893
    i had the same problem but all i did was take some car exhaust tubing and weld it on there, it seems fine.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
