It might just be stretched beyond it's limit. You can get a brand new one off of eBay for like $15.00. Since you have it torn down that far already, it'd be a breeze to change.
Regardless of what the manual says, you DO NOT have to remove the engine from the trike, the head,the valve cover, or the cam. Just take all the CDI stuff off. Unbolt the gear from the cam and slide it down on the nose part.
Remove the old chain and fish the new one down through there. Loosen the tensioner all the way (In fact, I took it right off) and pop the new one on the gears.
I did a complete timing chain swap from start to finish in under 45 minutes, taking my time.
Oh yeah, VERY important. Make sure the timing mark is on the T and the dot on the cam lines up with the triangle.
1981 Honda ATC 185s
-DG Exhaust
-200x Carb
-Uni Filter
-Air filter box removed
-10T Front Sprocket
-Plastic fuel tank
-Aftermarket seat
-200s front forks/shocks
-Aftermarket 4 bolt rear wheels
-Tire chains when ice riding
1988 Ford Mustang LX 5.0L
-Wayyyy too much to list!!!
