Results 1 to 7 of 7
Thread: flywheel install
    Ithaca, NY
    2,596
    flywheel install
    what is the trick to this? I know you shant whack it with a ! Do I need a helper to hold the motor from turning whilst I tighten the nut? Is it better to have the chain and sprockets installed so as to keep the motor from turning? Whats the proper method?
    Im planning on working on the Z today, possibly some pics of the progress later.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    I just tap it on with my fist and use an impact wrench.
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    Ithaca, NY
    2,596
    that is what I thought,but is it right? can I knock the crank out of true or something??
    louisiana
    47
    Its more about dislodging the magnets or breaking them I think. I used light taps when removing flywheels one side then the other. Some times you have to put a lot of force on the remover tool. Anyway thats my expierence.
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    Holic, you can tap it on, use a rubber and dont smack it like you wanna break it, LOL, just lightly.. You dont wanna up mess the magnets, and you dont want to push the bearings sideways. The bearings are not made to take much stress side to side, so they wont handle much. To tighten it down you can use an impact and that wont hurt it, or what I like to do is have the engine in the bike with the chain on, throw it in gear, and have a buddy sit on it and hold the brake while you tighten it,. Or if you have the engine out, and you have the other sidecase off, you can use a clutch basket holder on the basket while you tighten it.
    Rittman, Ohio
    6,276
    Ive always used an air impact, and my orginal flywheel is still going strong. The magnets wereent made by Kawasaki! If you are really worried about it though, you can get on of those rubber strap wrenches, similar to an oil filter wrench, that the sell at Sears.
    Before I used an impact, I would put the bike in gear, put a ratchet on it and give it a few whacks with a normal sized . Its sounds abusinve, but its not really any harder on it than gunning the throttle. It doesnt need to be extremely tight, but Ive always couple it with locktite on the threads and where the flywheel seats on the shaft after a few sheared woodruff keys.
    Ithaca, NY
    2,596
    thanks, its on and producing electricity, just got to find out why its not getting to the plug!
