Results 1 to 3 of 3
Thread: Disk brake rotor help
    Roanoke, VA
    4,038
    Aright ya'll....I need some info on brake rotors. I need to replace the one I have on my Foreman. It is gouged around the top edge which is eating my pads up. Basically, its a cheap POS rotor with some sharp edges on some of the slots which also eat up my pads.
    Now Im looking to replace it and I need to find a cheap replacement which they dont have. (I got the kit from H-L and its a one of a kind so a replacement will be expensive)
    If everyone with a rotor laying around for a ATC/Z/T3 or anything else could measure them and let me know if they match up, or if its close.
    Mine is about 8" in diameter and mounts with a 4/110mm bolt pattern. Please, if you have a rotor that matches this, let me know so I can get me a new one
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Apr 2002
    s.w. michigan
    6,498
    disc
    you need 4 bolt type of rotor right ,,, ? i have sevral loose 3 bolt type that are off of r or x trikes
    john
    Roanoke, VA
    4,038
    Yes, I need a 4 bolt rotor. I had to press in new studs on my rear hub, and the rotor actually bolts onto the rear of the wheel studs. So the bolt pattern is the same as the wheels....4/110
