Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Tri-Z 490 project
    May 2002
    Texas
    2,670
    The WR500 I remember form the early 90s was basically a YZ490. Same air-cooled motor with the wide ratio tranny. I do remember some YZ360s from the same time frame that were based on the 250s. They were kits.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    350Xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Huntington, W.V.
    320
    My buddy has a 84 YZ 490, 4 speed, and it is a brute of a motor it has a ton of compression, and it has a lot of power, but it does vibrate a lot unfortunately, I have rode it quite a bit it is a good all around bike, but it fouls plugs every now and then and he is running 50:1 Klotz. The YZ 465 was a superior motor as far as I know, having not ridden one though I can't really say,and 5 speed to, so it may be a better motor to use. The old 360 motors were good to, but a tad outdated, we used to have a DT 360 it was a good ole bike. Any yamaha or honda motor is really pretty good, but I say the 465 may be the best pick if the cases are the same like Tim said. As far as the wr 500's I have heard that they didn't run real well for being 500's as far as power goes.
    ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
    theeechozen1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2002
    368
    I would love to see someone put a wr426 motor in a tri-z, That would be a beast of a trike, with a wide ratio tranny to boot! Has anyone on here ever done a 4-stroke conversion on a sport tirke like that??
    1985 YAMI TRI-Z RZ350 POWERED
    1986 250R STOCK WITH FMF & K&N
    1986 TRX70 mini golf cart
    TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
