well....you could take a die grinder and cut a little wedge out of the a corner of the whole, then get a bolt in the nut pull on it and tack weld the bolt in where you cut the wedge out, after that unthread the bolt out and run a tap through it to make sure you get any slag or little welds out of there...then you should be fine...grind the weld off if there is too much and hit it with some black paint....
