Results 1 to 9 of 9
Thread: Spark plug difference
    kando is offline At The Back Of The Pack Arm chair racerFirst time rider
    Saskatchewan
    212
    Whats the difference between a B8es and a B6es. My yt125 three wheeler seemed to start a lot better with the B8es on a cold day. The dealer said B6es is for my machine. Yamaha part # says champion N9YC0-00-00. Also which NGK plug matches the champion, and is the b8es a hotter plug than a b6es.
    1982 YT 125 Yamaha 1984 Honda 200 m
    Front royal, va
    2,186
    the lower the number the hotter the plug, a"r" in the number means there is a resistor in it
    Rittman, Ohio
    6,276
    Tne lower the number, the hotter the plug for NGK. Champion is the opposite. The differences between the two plugs take affect after your machine is running, so they will not affect how easily it starts. I dont recogize the Champion plug you mentioned, but a B8ES is an N3C, so a B6ES would be about an N5C. Are you sure B6ES is correct? Most stock Plugs are somewhere between B7ES and B9ES.
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    The plug will affect how it starts. A colder plug will be harder to start. Usually this isnt noticable but it is sometimes.
    Saskatchewan
    212
    Quote Originally Posted by TimSr
    Double checked and bike bandit says iys a BP6ES
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by HaggLE
    You won't notice a difference because it's the same voltage and same spark. Heat ranges don't refer to anything that would affect starting.
    Jan 2005
    330
    The plug is more efficient at that range rather than one that is optimised for a hotter temp. Therefore it would work better.
    May 2002
    3,658
    It makes no difference for starting, it's the exact same spark.
    Jun 2004
    potsdam ny
    1,227
    anybody had any kind of performance gain from a certain plug type? (tapered elctrode, iridium, platinum,......)
