Results 1 to 11 of 11
Thread: 1983 185s stock sproket size
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    What is 1983 185s stock front sproket size?
    I need more torque and pulling power and want to replace.
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    11 tooth for the front.
    crackshot's Avatar
    Idaho
    1,024
    So if I installed a 12 tooth (larger), that would get me a little more torque and pulling power?
    83200e's Avatar
    Aug 2004
    Arkansas
    356
    Go for a smaller front or larger rear.
    crackshot's Avatar
    Idaho
    1,024
    Ok. thanks for the info!
    What's the stock rear sproket size? 40 tooth?
    Jun 2004
    Brazil, Indiana
    1,389
    41 tooth rear 11 toth front is stock...id keep trailprotrailpro 11 front and get a bigger rear..if u can find any rear sprockets that are bigger..i cant find any at all stock or not for my 83 185s..then go with a 10 tooth front..you WILL notice a difference moving front sprocket sizes
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by 83185s
    So how much difference will the 10 tooth make?
    Pulling power difference and torque?
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    I went to a 10 tooth front (with no other changes at the time) and it made a HUGE difference in low end performance.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by StangLX302
    Wow thats just what I need.
    I have a 10 tooth sprocket on the way for a whopping 6 bucks.
    Jan 2005
    Oshkosh, WI
    9
    I just put an 8 tooth front sproket on my 83 185S, I did not change the rear sprocket yet. This baby is nothing but torque in first and second gear now. I use my trike for ice fishing so the speed of the trike was not a concern. First gear was plenty fast enough before now I probably wont get out of second gear. You can pick up a rear sprocket for a 200s for cheap on ebay, it will fit the 83 185S and it will be 43 teeth. Another note on this 8 tooth front sprocket, I had to remove the chain tensioner in order to get enough movement to tighten the chain. I am going to try this for a while but may end up switching to a 9 tooth. The torque is enough that the rear brake does not hold if you hit the throttle too much.
    crackshot's Avatar
    Idaho
    1,024
    Update.
    I did get my 10 tooth sprocket and replaced. Man, the old 11 tooth looked like a throwing star.
    Our snow is melting and really heavy and wet so I went for a jaunt,
    I did notice better performance and did not have to rap out the engine as much.
