Anyone ever try using the rear shock linkage (cushion and pivot arms) on a 1986 R?
The bushings for the R are discontinued and the TRX is NOT the same (same width but thicker diameter). If both arms would work on a trike though maybe I could find them on ebay for cheap. Just need to know if they work with the stock R swingarm and shock. I know the bushings for the TRX are bigger in diameter but I don't know if the bolt is the same size. Maybe they're just thicker and use the same size bolt. Otherwise I'd need a shock too I guess which isn't feasible.
