Results 1 to 7 of 7
Thread: Please help!!! 350x chain problems
    Baton Rouge,La
    73
    My 350x came stock with a 13/40 sprocket ratio....the guy before me put a 14 on the front. I am trying to put a 12 on the front now. With that said, I just took the 14 tooth off and put the 12 on. The chain was obviously too long. I tightened the chain as far as the egg shaped carrier would allow, but the chain was still too loose. Like any "shop engineer", I decided to take a link out of the chain....Now with the egg shaped carrier as loose as I can get it, the chain is about 1/4" from fitting together and even at that, it would be way too tight.....
    What in the hell do you do about this? I know a new chain would not be stretched as much as this old chain, so maybe number of links I had before removing one would be okay....But what do you do when the new chain stretches and you can't tighten anymore besides buy another chain????
    Any help would be greatly appreciated!!!!
    '85 250sx Fresh
    '85 350x Even Fresher!!!!
    Jun 2004
    potsdam ny
    1,227
    get a half master link...they have them...i wouldnt personally use them on my R cause i dont think they look very strong, but they make them and sell them at almost every off road parts place......that will more than likely solve yur problem im guessing....
    Nov 2002
    Kirkville, NY
    3,831
    Yes, you can get a half link. Make sure that your rear sprocket isn't worn out too since you are back there. When chain stretch beyond adjustment then they are worn out and need to be replaced. "Chain stretch" is not caused by actual stretching of the chain; it is that all the little pins and links wear out.
    Don't forget that spending $30 on a new chain now can save you from having to fix a hole in you case later.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    NE Arkansas
    2,344
    i'm in the same boat with my X,,,got the new chain and sprockets in today,,,90 links? is that right???
    later
    My Rags
    Mar 2004
    Andale, KS
    114
    I recently bought a new chain for my 14/40 sprockets. I bought a 92 link chain and had to buy a half link. I think it was two dollars or something like that. It is pretty strong and hasn't broken yet.
    Current Rides:
    1986 350X-My play bike!
    1985 250R-My dune baby!
    Past Rides:
    1983 250R
    Jun 2003
    South of Rochester, NY
    3,470
    Quote Originally Posted by TravEX
    later
    hmmmm... seems like 92 is the correct length by memory....
    EDIT - and memory was wrong.... 90 is correct for stock gearing.
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    It is 90 links for stock gearing
    85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
    85 Big Red
    83 KLT200
    82 ATC200
    If it aint broke fix it anyway because it soon will be
