110 crappin' out problem possibly found
My kids 110 run great when first running then seems like it was missing after running for a while.
Been fouling plugs more than usual.
Took off the breaker points cover to check gap and clean.
Ran engine before gapping and noticed spark was shooting right to the plate where you screw points to.
Cleaned points which looked burnt on a side, with fine emory cloth, blew them off and fired it up.
Made the spark worse idling when you rev it up, does not ground out as bad but still grounding out.
I ordered a new set for 6 bucks.
So for people out there with atc's with points not firing, running crappy, check the point and run engine with cover off to inspect.
//ArrowChat Integreation Code
