Results 1 to 12 of 12
Thread: Chain lube - What kind you use?
    Jan 2005
    Slatington PA
    4,372
    Just want to see what everyone is using thats all.
    the stuff I use is called "lucas" chain lube and it works awesome!
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Feb 2003
    485
    I use PJ1, and Amsoil. I try and get the "No Sling" stuff if possible. I lube before and after every ride.
    Signature:
    1985 ATC350X
    1986 TRX-250R(Soon to be an 87)
    2001 Polaris Scrambler 90
    2004 Arctic Cat DVX400
    2003 Yamaha Blaster
    2005 YFZ450
    Rip: To many to list........
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    I use 80W90 gear lube. You know, the stuff you put in the rear end of a car. It's probably the wrong thing to use, but it's cheap and I've never had a problem.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    Apr 2003
    Bay Area CA.
    2,638
    i use bel-ray
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Dec 2003
    SE PA
    683
    Maxima chain wax. I run only o-ring chains. An o-ring chain is permanently sealed and lubricated. It only requires a coating to protect the seals. I ride in coal silt, and you don't want to use anything that stays wet or tacky (such as gear oil), as it will hold dirt and contribute to premature chain wear.
    Jun 2004
    geraldton, west australia
    1,068
    i use bel-ray spray on...it puts a non sticky white coat on the chain...great stuff
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Jun 2004
    Brazil, Indiana
    1,389
    i use wd-40 or 80w90 bar and chain oil for chainsaws..whichever i find first..i try not to use the wd-40 unless i have to tho
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    619
    I haven't used anything for years and have found that it doesn't make much difference in chain wear. I only put on a little WD-40 after washing to displace water.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Jun 2004
    potsdam ny
    1,227
    i use regular old chain lube you can get anywhere...i figure if the chain is lubed, its lubed. and thats the bottom line.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by hrc85250r
    Not so! Some chain lubes are way too tacky for dirt riding and actually make the dirt cling to it........and that's the bottom line!
    I have found Honda that goes on clear & Belray super clean that goes on a white-gray color (a few mentioned already) are the best that I have ever tried. DO NOT get the Belray wax type!! Thats the worst ever as far as I'm concerned. Probably any of the "wax" ones attract the dirt.
    I got the other type belray by mistake one time.I wouldn't even give that stuff away! It was that bad.
    Jun 2004
    potsdam ny
    1,227
    Quote Originally Posted by Huffa
    true, some do collect dirt, but after a good ride the chain needs to be relubed and usually has dirt on it anyways, so after it gets pressure washed i always relube it....i use white lithium chain and cable lube, i have never had a problem with it on my renthal o-ring chain and i have had it for 2 years now...
