Results 1 to 9 of 9
Thread: 200X Leaking Gas...no clue from where
    Toronto, Ontario
    70
    Ok, I get gome tonight from the Auto Show, Im extremely tired from a full day of walking but I want to fix my Trike...I get home to a big spot of gas on the floor of my garage, directly underneath my trike...my garage smells like gas, and the spot is gas, Im absolutley sure it is...there is gas on the engine, but I cannot follow the leak anywhere because it seems to be evreywhere...I dont know if its a gas line, or something else...right now I turned the gas to OFF and am hoping it stops the leaking until the morning...its not a big leak, but its big enough to notice a pudldle of gas after about 10-15 minutes...also, Im sure I did not spill gas as I was filling it up as I am very careful when dealing with fuel, because I know how it can damage paint finishes, that is why this problem is killing me...I searched and read that it could possibly be a overflow...but why would my tank overflow when I rode it yesterday perfectly fine without any gas on the floor of my garage...Im afraid to start it because there is gas almost evreywhere over the engine and my exhaust likes to backfire...with the fumes in the air, I smell a news story already...Please help, as fast as possible, if you need more info just ask, if you want specific pics of something, just ask...HELP!!!
    incase it matters its a 85 200X...
    Thanks alot for your time, and just remember im still quite new to this so dont get TO technical with me...
    1985 Honda 200X
    Mods: Cobra Exhaust, or so I was told....
    Feb 2005
    Oregon
    772
    Im not sure this will ansewer it but it is a thought, if you leave the gas in the on position it will leak out of an overflow tube that is hooked up to the carb, ive done that with my tecate once
    Toronto, Ontario
    70
    but I alawyas leave my gas on,,,ALWAYS....since I got the trike in November it has never been off...why NOW it decides to do this? this is really weird...
    1985 Honda 200X
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    All it takes is a speck of crud to get in the float needle seat, and the gas will run out of the carb. The other thing that can happen is the float needle sticks.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Phoenix, AZ.
    6,719
    Well first thing you do is take the tank off and get it out of the garage if you're that worried about it. It only takes a couple of minutes and would make it a lot easier to find the leak. Take it off, look for holes or a leaking seam. Leave it outside until you fix it.
    Toronto, Ontario
    70
    But the gas tank is full of gas...not overly full, but its got a nice amount in it, would it still come off easily? or would the tank have to be drained?.....now that I turned the gas off it stopped leaking...WTH this is pissing me off now....
    1985 Honda 200X
    Jan 2005
    south manitoba
    273
    well you now know the tank doesn't leak. take the carb off and clean the sucker..problem solved! or try run some fuel injector cleaner first. that might do the trick and a whole lot less work than manualy cleaning a carb.
    1985 250sx.
    1991 trx 200,1500 superwinch,snow plow(hers)
    1985 125trx. kids toy
    05 baha 90 mini quad
    110 atc (just picked it up)
    garmin map60c
    Mar 2004
    Gettysburg PA
    498
    Quote Originally Posted by 1985_250_ATC
    yes you can still take your gas tank off if its full just make sure to turn your petcock off fist. if gas is leaking its most likely out of your carb overflow. take the tank off and then take off your carb. what i would do is take the carb apart and make sure the floats arnt stuck, aslo check the needle and seet to make sure they are not shot. if everything looks ok. clean everything off with brake parts cleaner. do NOT use a carb cleaner enless you want to replace all of your gaskets. Brake parts cleaner works pretty good dries fast and it is not bad for the gaskets good luck
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    Toronto, Ontario
    70
    Alright evreybody, thanks alot for the help, this looks like a next weekend "project"...I will have to look over the shop manual to see how to do certain things but from the way it sounds, its not to hard...thanks alot guys!
    1985 Honda 200X
