Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: let me ask a few things
    Jun 2003
    South of Rochester, NY
    3,471
    Quote Originally Posted by My trike Sucks
    says right on the bottel for use in wet clutch atv's...works great and it makes the bike 10 times easier to start in -30 weather, mind you this is a 4 stroke, with a 2 stroke starting wont haven any effect on it
    well.... that's a different story! Synthetic car motor oil is what I am talking about. Has friction modifiers in it. That would be the bad stuff for clutches.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Aug 2004
    Ab Canada
    4,368
    ah yes, the friction motifiers, i just thought everyone knew not to use the oils that have them in there for bikes? meh whatever :P
    1985 Tri-Z-
    Jun 2003
    3,471
    well... we got a lot of newbies on here.... can't assume much these days!
    Jan 2005
    Springfield
    328
    Thanks for all your posts guys! ive been buying texaco synthetic 10w-30w from walmart.. i dont suppose this is any good? will any motorbike oil do? aslong as its for wet clutch?
    So if my trike is wet clutch i dont need the clutch when changing 2nd,3rd,4th,5th,4th,3rd,2nd,1st ?
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 350x'inNY
    Bruce
    I was just about to post the same thing.
    Jan 2005
    Slatington PA
    4,372
    An oil with this label (circle) on with NO "energy conserving" print in the bottom 1/2 is fine for trannies. All oils have this label or at least should. This is exactly how it should look for oil that you CAN use.
    Rittman, Ohio
    6,276
    Ive never had a problem running any off the shelf automotive oil, synthetic or otherwise in a 2 stroke bottom end. Synthetics dont necessarily lube better. They last longer before breaking down, and breaking down is a chemical process from combustion byproducts, something you dont get in a two stroke. So there are no real benefits to running synthetics in a two stroke case, but its wont cause any problems either.
    Ive got a simple question for everyone who feels that better quality oil counteracts the benefits of "friction" plates. What is the purpose of the oil your clutch is bathing in? If you understand the answer to that question, the real purpose of teh oil, it is easy to conclude that the better your clutch is lubricated, the less likely it is to slip.
    If anybody really cares why this is so, Ill be happy to explain it, but its usually one of those topics where everybody has their mind made up, so Im not going to twist anybodys arm to see it my way. Ill simply challenge them to get the years and years of slip free sevice I get from a clutch.
    Jan 2005
    Springfield
    328
    my honda dealer said synetic oil is fine to run. and will cause no clutch problems. he also said use 10w-40w all year round. and the other think i dont get is he said to 4 litres put 100cc of oil... i dont get the 100cc. i know its 25cc to a litre but what is cc?!
