Thread: atc 110 over bore
    Feb 2005
    u.p. of michigan
    Question atc 110 over bore
    hello all new user to this forum i have a tec question i'm hoping someone could help me with. i am wanting to bore a atc 110 jug to fit a 125 piston trying to make a big bore for it. does anyone know if this is possible? i have lots of mods in mind for this motor. any help would be greatly appreciated.
    Shrewsbury, West Virginia
    564
    No, you can't bore a 110 cylinder out that much. A stock cylinder is 105cc. I bored mine .030 over because of deep scrathes on the cylinder walls and I only gained 3cc, so instead of 105 I have a 108...still not even a true 110.
    I don't think the 125 cylinder and head will bolt up to the 110 bottom end either, but I think the 125 motor will bolt into the 110 frame. Like I said though, I'm not totally sure.
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Jun 2004
    geraldton, west australia
    1,068
    hondaatcman is correct.
    you cant bore the 110 cylinder out that much
    the 125 jug wont go on
    and the 125 engine is a near perfect fit
    cheers
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Feb 2005
    Western Australia
    18
    have a look here this bloke did a Honda CT90 to a 125
    2004 110cc Pitboss
    2000 XR50R
    1994 XR600R
    1984 LT50
    1974 ATC70
    Feb 2003
    Australia
    927
    You can bore the 110 cylinder to 125cc. A piston out of a Honda 125J is 56.5mm and it works just fine. Better still search Ebay for 55 or 56mm big bore kits for a few extra bores. There are tons of them kicking around some of the older shops. I don't know why that bloke bothered with the 125 top end conversion when you can bore the CT110 to 125cc using the same pistons I just mentioned.
