Results 1 to 11 of 11
Thread: For all you guys with 1985 350x's
    Jan 2005
    las vegas nevada
    157
    If you want an extended swing arm , get one from an 86 350x , they are about a 1.25 inch's longer than the 85's. You will have to cut the brake mount off the 85 and weld it on the 86 swingarm. It is also gusseted which the 85 swingarm isnt .
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    realy, I have never heard of that
    85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
    85 Big Red
    83 KLT200
    82 ATC200
    If it aint broke fix it anyway because it soon will be
    Jun 2003
    South of Rochester, NY
    3,471
    Hmmmm... then why do they have the same chain length? Think you got some WRONG info.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Jan 2005
    las vegas nevada
    157
    Dude i put the 2 side to side and all .,i even used a tape. Im tellin u its 1 inch longer .
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    maybe they have different sprocket gearing and that makes the chain the same size
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Jun 2003
    englishtown NJ
    2,676
    how can I tell if I have a 85 or 86 swinger, my 350x is a 86 frame, but has 85 tripples(not tapered bearings), I was able to put a 250r caliper plate, caliper, brake hub and such on the 350x I have, do I have a 85 or 86, as I need to order a carrier. Also the rear shock is held on by two bolts in the swingarm one goes under the bottom and the the other one goes through it, and I can't get the one that goes through the swinger out. Are the 350x's standard with dual piston front brakes, mine has them, it looks like a 250r caliper and with the 350x caliper plate a 250r brake would fit, this is my first 350x. according to rockymountianatv.com the chain is longer on a 86 350x. my 350x definetly has a 86 motor, due to how the cluth cable is run, or could that be easily changed?
    Jan 2005
    las vegas nevada
    157
    On the 85 swing arm on the left side you will see a stud where the brakes bolt on to , on the 86 it doesnt have it so you have to cut it off the 85 and weld it on the 86. on the 86 on the left side the stud wont be there
    Jun 2003
    englishtown NJ
    2,676
    ok, so it kinda like how the 85 250r caliper mounts compared to a 86. I have a 86 swinger then.
    Jan 2005
    las vegas nevada
    157
    yep i guess so ! i had a 86 swinger on my 85 r but it was on it when i got it
    May 2002
    Southeastern Wisconsin
    3,658
    I'm no 350x expert but I'm betting that one of yours is an aftermarket swinger.
    Jan 2005
    las vegas nevada
    157
    hell maybe it is ill post a pic
