Hopefully this is a simple question. Do 84 and 86 200x carburetors interchange?
Thanks
Chris
Thanks
Chris
montgomery ward T555
honda 185
BTTT
someone has to know here........
honda 185
bttt......
honda 185
I don't know if they fit but I do know that there are different positions that you can mount the intake so that the carb does not hit the frame.I think that is the main thing to worry about.
1985 Ytm 225 dr (Black and gold)
1984 Kxt 250 A1 Tecate
1981 KLT200a1
1983 Yt 175
1985 Atc 350x
1983 Klt 200 C
1985Ytz250 Tri z
I beleive that they are simliar in design but they are different. I know that they use different carb kit part numbers. They might interchange between bikes but I am not 100% on that.
1985 Honda ATC 350X
2003 Yamaha Banshee
2003 Polaris Sportsman 500
There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
I took a 200x carb and put it on a 200e bolted up just fine. As long as it fits "Flush" too the intake tube and bolt holes line up you should be fine. if it does all that but dont fit air box thats up too you. modify air box tube too fit or take it out and run a filter with clamp out back ex. k&n,moose ,uni. or whatever.
By the way you have a fixed intake tube right? not a reed cage?
