Thread: premix ratios
    Jun 2004
    potsdam ny
    1,227
    premix ratios
    what is the best ratio for power and durability for the bike that is in my signature?
    i have been running 20:1 forever and i know that is too rich, but the thing is i have a friend that is a semi-professionalish dirtbike racer that is sponsored by ktm and he has always ran 20:1 in his race bikes....idk, he rides ktms and i have an old 250r so its probly different...
    thanks...
    Feb 2005
    Oregon
    772
    32:1 is pretty standard, it is a good mix, its a little on the rich side but not nearly as much as 20:1
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    May 2002
    Southeastern Wisconsin
    3,658
    Depends on the oil. I used to run 20:1 with cheap-o wal-mart oil then I got into super techniplate. With Klotz super techniplate I run at 50:1 and now I have more power and my cylinders are lasting a lot longer.
    Jun 2004
    potsdam ny
    1,227
    right now all i have is pennzoil marine tcw-3 oil, im guessing its pretty crappy, but the only time that i ran supertechniplate i siezed my crank....lol...but it smells good!
    Feb 2005
    Oregon
    772
    Try out HP2 its fully sysnthetic, wich has been proven to last longer than normal 2-stroke oil.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Aug 2004
    Ab Canada
    4,368
    it makes sense that a guywho races bikes would mix it at 20:1 becuse a 2 stroke motor makes its most power at 18:1....check out www.macdizzy.com
    1985 Tri-Z-
