Thread: Question for anybody running a high compression 2-stroke head .......
    Washingtons Crossing, Pa.
    2,977
    I just received my new "used" Hot-Seat performance, 12:1 compression, pump-gas coolhead, I won for a steal on eBay today and my question is: Do you have to "up-jet", at least on the main, when you install a higher compression head in a pinger?. I can't seem to get HotSeat to respond to my e-mails .......
    2,977
    Either nobody knows, nobody cares or you all hate me ....... boo hoo hoo, sniffle sniffle. The only thing I can think of is that I have found you do have to up-jet when you install a higher compression thumper wiseco piston, which would be a different means to the same end sort of .... the thing is, I really don't know with a 2-stroke. I mean in theory, you are just compressing the same volume of "charge" to create more power, right?.
    Rittman, Ohio
    6,276
    Quote Originally Posted by Wickedfinger
    Both!!!
    I dont know either, but what I do know is that everytime I see something that was jetted based on theory it was way to rich. The general rule is, if you change your plastic or get a new helmet, you have to jet richer. Id put it on, and take it for a run, check the plug frequently and go from there. I never rejet after changing something until Ive Ive got it running again and can verify which way, if any, it needs to go.
    May 2002
    Texas
    2,670
    Quote Originally Posted by TimSr
    Both!!!
    ... The general rule is, if you change your plastic or get a new helmet, you have to jet richer. ...
    Oh $h!t! I just put air in my 250R's Tires! Gotta go re-jet the Tecate!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    2,977
    Aint that the truth ..........
